Question about Peavey Music
Http://www.peavey.com/support/searchmanuals/
Owner's manuals and spec sheets that are not available on our web site may be obtained by mail (via money order) or by phone (via credit card). Spec sheets and schematics are $2.50 per copy, and owner's manuals are $7.50 (paperback) and $20 (notebook).
Send Money Order to:
Peavey Electronics Parts Department
PO Box 2898
Meridian, MS 39302
Credit Card orders by phone:
1-877-732-8391
Posted on Sep 25, 2017
SOURCE: Peavey 400SC
You can find Peavey's manuals in their archives at
http://www.peavey.com/support/searchmanuals/archived.cfm
They are grouped alphabeticaly across the top.
Go Fer' It,
FixThemAll.........
Posted on Dec 15, 2008
SOURCE: 9v battery wires came loose. peavey 5 string bass
The negative battery terminal will go to a black wire and that will be soldered to one of the volume control cases. That makes the remaining wire easy. The negative terminal pole on the battery is the larger round one.
Posted on Jul 06, 2009
SOURCE: Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Posted on Sep 22, 2009
SOURCE: I have a Peavey MAX
The amp is doing what is called "motorboating". This is usually caused when the voltages to sensitive preamp stages are inadequately filtered or regulated and the sudden load of the output stages cause a dip in the voltages sent to the preamps which in turn vary the input to the output stages starting the cycle over. This will require electronic troubleshooting and if your not skilled in that, then it is NOT a DIY fix. What you are seeing is NOT normal, there is a defect.
Posted on Apr 23, 2011
SOURCE: there are some burnt carbon resistors beyond
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
Posted on May 24, 2011
Aug 20, 2017 | Peavey Music
Apr 04, 2014 | Peavey Electronics Peavey Tour Tnt 115...
Sep 05, 2013 | Peavey Electronics Peavey Tour Tnt 115...
Feb 26, 2012 | Peavey Electronics Peavey Tour Tnt 115...
Oct 25, 2011 | Peavey Max 115 1x15 Bass Combo Amplifier,...
May 23, 2011 | Peavey Max 126 10 Watt Combo Bass...
Sep 19, 2009 | Peavey Music
720 people viewed this question
