Washer locks but does not start - Washing Machines
Posted by Alan Burrow on
richie46
    Top Expert:
  • Washing Mach... Master
  • 12,962 Answers
Posted on Sep 24, 2017
THE DOOR WON'T LOCK THEREFORE THE MACHINE WONT START
Washer Door or Lid Won't Lock - Repair Parts - RepairClinic ...
www.repairclinic.com/...Washing-Machine/...---/Washer-door-or-lid-wo...
Most Frequent Causes for Washer door or lid won't lock. For the most ... Once thewasher door is closed, the washer can begin operating. If the door lock is ...
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock thelock and ... The Kenmore Elite HE3 is a washing machine by Kenmore.
Front Load GE washer won't lock / start. ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Front Load GE washer won't lock / start. ... Based on your symptom and details it could have a faulty door lock assembly ... GE Washing Machines 3.8 cu. ft.
Washer Won't Spin or Agitate? Washer Door Latch ...
Dec 13, 2015 | Washing Machines
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
My GE Front loading washer has a red lock light
On the GE GFWN1100LWW the Lock light indicates that the Child Lock (Panel Lock) is enabled. Press and hold the Lock touch pad for 3+ seconds. The light will go out. (Note: if you hold that button for too long, the lock will disengage and then reengage.)
The lock is useful to avoid having someone change the settings or start the washer when they shouldn't. (For example, you don't want to start or change the cycle settings on the washer while cleaning the control panel's surface.)
I hope this helps.
Nov 25, 2013 | GE GFWN1100LWW Washer
Lid will not lock, Washer will not start: I press
There might be the issue of the lock as the control board tries to send signal to close the lock but it can not. This is common issue with the lock more than the control board.
Oct 11, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
FRIGIDAIRE FRONT LOAD WASHER WON'T START. DOOR LOCK WILL NOT LOCK. DOOR LOCK LIGHT IS OFF. PULL START HANDLE OUT/ NOTHING. HEAR CLICKING WHEN TURNING SELECTOR SWITCH/BUT WILL NOT LOCK DOOR OR TURN LIGHT ON...
Good Morning REDS, thank you for your inquiry!
I understand that your door indicates it is open and your washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle, confirmed the latched is securely latched and verify if the washer will start. If the washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 11, 2013 | Frigidaire ATF6000ES Front Load Washer
A red padlock symbol is showing on the panel of my WCVH6800 front load washer. I can't change any of the wash settings. How do I fix this?
Here's what the Padlock represents:
Lock Function
You can lock the controls to prevent any selections from being made. Or you can lock the controls after you have started a cycle. children cannot accidentally start the washer by touching pads with this option selected.
To lock the washer, press and hold the DELAY START button for 3 seconds (on some models use SIGNAL button). To unlock the washer controls, press and hold the DELAY START button for 3 seconds. The control lock icon on the display will light up when it is on.
NOTE: The POWER button can still be used when the machine is locked.
Jun 28, 2011 | General Electric WCVH6800J Front Load...
Door won/t lock to start washer
by pushing all the buttons the door finally locked and the washer started, thanks anyway.
Sep 29, 2009 | GE Dishwashers
Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Sep 29, 2009 | Washing Machines
Front load will not lock
are you getting three beeps when trying to start, if so door lock problem
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer Start/Pause button is Falshing and won't start
Try some WD40 on the door lock. The washer won't start if the door doesn't lock.
Jan 13, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
