Question about Kenwood Computers & Internet
Help installed wrong firmware on kenwood ddx 394
Installed firmware for ddx 393 by mistake, need original sytem ver .105
Posted by David Ball on
5 Related Answers
Anonymous
SOURCE: forgot code for my kenwood ddx-7015 can u help
How Do I Reset my pass code?
Posted on Sep 28, 2008
Anonymous
SOURCE: Need the codes
I can't find the code to unlock my ddx7015, can you please help me, or tell me how to unlock it.
Posted on Nov 25, 2008
Anonymous
  • 5 Answers
SOURCE: bypass for video on a kenwood ddx-512 car dvd player
On the wiring harness there is a green parking sensor wire (PRK SW) that you have to hook up. All you have to do is ground that anywhere on the chassis of the car then youll be set.
Posted on May 09, 2009
brian soufane
  • 693 Answers
SOURCE: No I'dont find that I
Go to this link http://en-us-support.belkin.com/app/product/detail/p/327
and download the new firmware
Posted on Aug 15, 2011
raingamj
Jordan Raingam
  • 2148 Answers
SOURCE: Need NOKIA X2 8.17 Firmware, Plz help.
.Here is your firmware. X2 firmware Thanks for visiting fixya
Posted on Feb 21, 2012
I have a kenwood ddx512 in protect mode i checked the wiring. Can it be the harness its self or the firmware?
protect mode on kenwood DDX512 is due to a burned out the output amp.,or in last case the tuner bloc is damaged. try checking first the amp. ic.
2answers
I need the wiring diagram for the Kenwood DDX 512 Dvd Player
You can download and print the installation and wiring manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa
1helpful
Kenwood DDX-514 label wires
90% of new and aftermarket harness' are the same, Red any Yellow are Constant 12v and ACC. 12v. Black is ground, Green is rear left speakers, Purple is the right rear. White is front left and Grey front right. Blue solid is Power Antenna, Blue with a white is an AMP Relay. (Which is another 12v ACC) You should have some sort of AV in/out lines for the rear screens, if that was an issue.
Kenwood DDX512 problem with IPOD
I had the same problem. Updating the firmware for the Kenwood resolved it.
Kenwood DDX 7017 bypass code
During code request mode:
Point the remote control to the screen and input this numbers (from the remote control) as faster as you can 55222277
You will not see any change on the screen until you enter the last number.
This will clear the code
If you make a mistake,just reset the unit and start from the top.
Thank you for rating
2answers
Need the codes
i need a code to unlock a ddx-7015
Only computer show cd rom can't work
You need to update the driver in control panel. Then it may see it or you might
Computers & Internet Logo
Top Kenwood Computers & Internet Experts
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Kenwood Computer and Internet Expert? Answer questions, earn points and help others
