Question about Minolta Office Equipment & Supplies
My machine minolta ep4050 print not darker when i darker in option
Posted by waqar ahmed khan on
Norman J Weimar Jr
  • Minolta Master
  • 6,960 Answers
Clean the mirrors in the scanner and replace the drum and developer
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 10, 2018
4 Related Answers
goalie39
Ed
  • 479 Answers
SOURCE: error code c0200 minolta ep4050
C0200, charge corona failure.
The high voltage wire used to charge the photo-conductive drum is broken or shorted.
It will need to be repaired or replaced.
It is usually a fairly simple job, but you may need the replacement wires to complete the job.
It could be someone has pressed the scoritron grid tensioner and allowed the grid to drop onto the drum.
Great care must be taken when working around the drum area.
If you open the front of the machine.
drop down the transfer section (yellow or green handle)
flip out the toner bottle.
you should see to recessed screws, one behind the toner bottle, one on the far right side of the unit. loosen these all the way,
there may be a plug in each side to disconnect.
you should now be able to slide the unit out.
set it down in some paper, the corona will be the long metal housing stretching front to back on the drum unit.
Remove it by sliding it one way, then it should open like a hinge, open it all the way and it should pop loose of the main unit.
The corona wire is behind the grid, it is the thickness of a human hair. If it is broken you will need a replacement, if the grid was off when you opened the unit up reinstall the grid and reassemble.
If the corona shell or the scoritron is discolored, clean them with a glass cleaner and soft cloth.
Keep the drum covered with paper so it is not exposed to direct light for any great length of time, do not allow the drum to be exposed to direct sunlight.
Hope this is of some help.
Ed
Posted on Apr 19, 2009
Anonymous
  • 5081 Answers
SOURCE: Turn on get error c0500
the error codes means Low fuser temperature during warm-up
To clear the fuser error code, perform the following after correcting the cause:
1. With power ON, open the front door and locate the small, rectangular hole below the imaging unit removal tool.
2. Insert a suitable object into the hole to actuate the reset switch .
3. The code should clear and a message to close the front door should appear.
Posted on Jul 06, 2009
RommelF
Rommel Fellizar
  • 11 Answers
SOURCE: We have a Minolta EP4050 with an error code C004.
Yes you need to call service this indicates problem in your fusing unit. A busted Heat lamp is the reason or broken thermistor.
Posted on Jan 13, 2010
Anonymous
  • 170 Answers
SOURCE: how to resolve erorr code
ckeck the main motor but try reset first the error to reset that error open the front door then at the left side of the machine you will see the small square attach with 1 screw remove that screw then the plastic square type then you will see the reset botton just press that botton
Posted on Dec 19, 2010
Copier Minolts ep4050 error code c0601
Scanner fault. The bright lite under the big glass. Does it come on To reset. Open the front door to your left a small access plate one bolt. remove the cover press trouble reset.
1helpful
How to resolve erorr code c0100 minolta cspro ep4050? [email protected]
Minolta EP4050 access code
admin or service?????
We have a Minolta EP4050 with an error code C004. Do we need to get serviced?
2answers
I have a Minolta model EP4050 and all of a sudden the display panel will not display. The copier works but I cannot see the display...it just lights up with the blue background light and that's it. Do I...
Sounds like the display HAS gone bad. I doubt a new one can be ordered. The best bet is to find a Minolta - Konica-Minolta dealer and they may have one in their graveyard.
2answers
Bizhub 350 doesn't print at night.
Check the driver, you should have availability.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
7helpful
3answers
Error code c0200 minolta ep4050
Ed
2helpful
Copier Minolts ep4050 error code C0072 +
C0072 is aerror code for the sub hopper unit. It is having a hard time adding toner or that the toner motor is ON for to long. It is having a hard time kepping up with the ATDC. The M2 is a counter, it can be reset in service mode, but major parts have to be replaced to clear it..
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Mehandi Husain ...
George Mclaughlin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
