Question about Locks & Locksmithing
My bunker hill safe does not lock back
My digital 1.5 cubic feet safe does not lock back , if door is open when I turn the nob clockwise it locks while door is open but not when I close it and try to lock it does not lock at all , I never had a problem with it until now please help
Posted by Nezihe Taylor on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
Posted on Nov 29, 2008
Anonymous
  • 3 Answers
SOURCE: Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
Posted on Aug 19, 2009
Anonymous
SOURCE: I have a small bunker hill digital floor safe. I
follow the following link: http://www.harborfreight.com/manuals/91000-91999/91006.pdf you will see a picture of the bunkerhill digital floor safe, ITEM 91006-6VGA, under the sale price, you will see in GREEN "download product manual. There you will find the instructions for this safe. It took me about 30 minutes to find, then realized I didn't have batteries inside. Lucky for me, I found the key. You will need batteries inside. Otherwise, call the company Monday-Friday 9:00am - 7:30pm EST at 1-800-444-3353 (toll free). For Technical information call Monday-Friday 9:00am - 4:30pm EST at 1-888-299-3427.
Posted on Nov 10, 2009
Anonymous
SOURCE: My husband locked both keys in the safe 94985...
Search on "How to open a safe with a potato" and you'll find a youtube video on how to open that safe. All the Bunker Hill safes use the same lock mechanisms which have a critical design flaw if the spring on the solenoid is weak in that the plunger bounces enough to allow the bolt to be thrown open if you can time hitting the front of the safe just right. Of course, if you mount it such that you can't get a good swing in then no problem. There are two adjustment screws to the bolt throw, if your safe is easily opened this way, you might want to adjust these screws so that more of the plunger hits the stop. I couldn't get mine to open with a rubber mallet but it's mounted so you can't get a good swing in.
Posted on May 13, 2010
Prentice Hill
  • 51 Answers
SOURCE: i have a bunker hill
You should have a key for emergency backup. The plate next to the keypad covers it. :-)
Posted on May 31, 2011
How to change code N15115
Input the new code (1-8 digits then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again Emergency Key - store in secure place NOT inside the safe. To ensure the batteries have been installed correctly test before closing the door. 2 bolt locking mechanism, opens with a digital code or emergency key. Floor or wall mountable, immediately locks out after 3 invalid code attempts. Durable steel construction, model Name 24/7 Digital Safe, material, galvanised steel. Opening the safe a. Pre-set factory code 159 b. Input 159 (the yellow light will flash and the buzzer will beep then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened Closing the safe: close the door, input the code (the green light.
Feb 01, 2015 | Home Security
Can u assist me with opening my safe
Our tech team at Quality gun safes wall safes and floor safes store in Burlingame Ca produced this video
Nov 04, 2014 | Sentry Fireproof Safe
I can't get the lock to disengage so now it's locked...open!!
You must enter the code to unlock the safe, just as if the door was shut. The safe does not know the door is open and you just need to shut it.
If you have entered the code and it unlocks properly but you still can't disengage the bars, take the panel off the inside of the door and inspect to see what is causing the problem.
Jan 10, 2014 | Mesa Safes MFL2014E Safe Depository Safe...
I put in my combintaion, the batteries are good, the lock shows unlocked, but the handle will not move
I would say try replacing the battery holder. A1 Locksmith Burlingame CA 94010 have Sentry safe locks, keys, battery holders, battery door covers, and door handles. New parts reclaimed from damaged freight returns. But only a small supply in stock.
Feb 26, 2012 | Sentry Safe Fire-Safe OA5865 Electronic...
I HAVE A GRAFTER ELECTRONIC DIGITAL SAFE WITH A LOCKED DOOR, NO KEY, NO CODE AND AT THE MOMENT NO LUCK. CAN YOU PLEASE HELP. ?
If the safe isn't fixed to the wall or floor, then you can easily open the door in seconds.
Just balance the safe on it's rear edge, tilted back about 45 degrees, so the front is about 4" off the ground.
Hold the door release gently and allow the safe to fall flat, as you hear the impact, turn the release clockwise. Timing is everything and it took me 4 goes to get it right.
Jun 20, 2011 | Safe International Digital Electronic Safe...
How do you lock it?
Hi Celsa,
Please follow the below instructions to unlock and lock depending on the series of sentry fire safe security you have.
H & F Series:
To unlock and open:
1. Insert key in lock and turn counterclockwise.
2. Apply downward pressure on top of the safe, while
pushing the latch in to release.
NOTE: Due to compression of the gasket, the
unit will require slightly more force
than a safe that does not have a gasket.
To close and lock:
1. Close and press down on lid to engage latch.
Safe can now be transported without locking it.
2. Insert key in lock and turn clockwise.
HD & FD Series:
To unlock and open:
1. Insert key in lock and turn clockwise.
2. Pull up from bottom
of latch while pushing
down on lid to release.
To close and lock:
1. Close and while pushing down on the lid, press down on
the latch until it is secure.
2. Insert key in lock and turn counterclockwise.
For the complete manual with images you can click on this link :- http://bit.ly/lzdBP2
Hope this helps.
May 11, 2011 | Sentry 1110 Fire Safe Security Chest
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Locks & Locksmithing Logo
279 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
