How to print hpcsa card - Office Equipment & Supplies
Posted by lethukuthula on
What is the best site to print Business Card?
https://www.vistaprint.ca/?mk=vistaprint&ad=e&crtv=171492698830&device=m&psloc=9000861&pstid=aud-285246831786%3akwd-104664860&psite=mkwid%7cNq0ZSguh&iv_=__iv_p_1_a_7549902_g_5767695162_w_aud-285246831786%3akwd-104664860_h_9000861_ii__d_m_v__n_g_c_171492698830_k_vistaprint_m_e_l__t__e__r_1t1_vi__&gclid=EAIaIQobChMIxLW4xYXU1wIVCnd-Ch1Rig6GEAAYASAAEgJbavD_BwE&GP=11%2f23%2f2017+01%3a14%3a24&GPS=4604228398&GNF=0&rd=1
Nov 23, 2017 | The Office Equipment & Supplies
My fargo hdp600 keeps printing a white edge in the front of the card
please go to the print preferences and card there you will the card adjustment card size print width print length and card type are all there you can make your ajusment there and also patriot or lanscap
Mar 22, 2014 | Fargo Office Equipment & Supplies
Good afternoon, I am having problems getting my printer to print a complete card without telling me that the ribbon is broken. The error code I am receiving is PR-01724 The Printer I am using is the...
PR-01724 Ribbon Break
The print ribbon is broken.
Possible Cause 1: The print ribbon has broken or is not installed.
Solution 1: Trim the broken ribbon evenly and tape the cut end of the ribbon to the ribbon on the take-up spool. Install the ribbon cartridge.
NOTE: Do not switch take-up spools when fixing.
Possible Cause 2: If the ribbon type is K or KT, the print ribbon is at the end of the roll.
Solution 2: Load a new roll of monochrome print ribbon.
Technical issues:
•If you have recently changed edge-to-edge settings using the SmartDriver, printing might be too close to the edge of the card. Change edge to edge settings.
•You might have moved the print ribbon while the printer power was off. The next card will print correctly. The printer is designed to allow you to fix problems while the printer power is on.
•If the print ribbon is stuck to the card, the Intensity setting might be so high that printing causes the ribbon to stick to the card. Lower the Intensity or power setting.
•The card design might be longer than the card size. Change the card design to be less than or equal to the card size in the long direction (3.37 inches or 85.60 mm).
•Printing might not be positioned properly on the card. Change the "Left/Right" position of printing (using the SmartDriver) so the printing begins and ends on the card.
Jun 20, 2011 | Datacard SP55 Plus Printer
How do I print 3 x 5 cards with my HP C5180?
HP does not recommend printing 3 x 5 cards on this printer. It has a tray for printing 4 x 6 photos but, that is the smallest size available. However, you can set up Microsoft Word to print 3 x 5 cards on regular letter paper and then glue them to the cards. Or you can print them on card stock and cut them out.
Hope this helps. Robert
May 06, 2011 | Computers & Internet
Evolis Pebble 4 with a gold monochrome ribbon. Printing on pre printed blank cards. The print is not complete, almost as if there is not enough pressure on the card as it is printed. All the letters are...
Make sure you have selected gold ribbon in printer graphic properties.
Also you can try changing luminosity and treatment options in graphics under Advanced setting.
Check for print on a white card also as problem may be due to card surface also .
You should cklean print head also at once.
Oct 04, 2010 | Evolis PEBBLE 4 Led Card Printer
Will not print photo. Asks for card. Need to print from computer, not from photo card. It has worked in the past.
You just have to send the print request from the computer, if you press the photo button on the printer it will always tell you to insert the card. It knows how to print when it's sent a print request.
Jan 18, 2010 | HP Photosmart A610 InkJet Printer
Print quality with Fargo DTC500 printer
You might go to the print driver settings to change the way the printer prints the card. This can be found in the printing preferences. Go to the device options tab and choose "rotate front 180 degrees". Then print a card. This may fix the problem.
If not, try downloading the latest print driver from www.fargo.com.
Visit our id card printer technical assistance blog at www.safecardid.com/blog.
Sep 24, 2008 | Fargo DTC525 ID Card Printer
My Business Cards
You need to set the print size to match the size of the card.
you either need to resize the document or change your print preferences to match the size of the card.
May 16, 2008 | Avanquest MyBusinessCards (824592)
HP 1310 series
I have an HP PSC1315 which is virtually the same printer. I actually created my own template where 10 business cards are printed as if it were one sheet of paper(like a poster). Of course you you can't select how many cards print, or which card to start on, but at least I get 10 perfectly centered cards.
Sep 04, 2007 | HP PSC 2210xi All-In-One InkJet Printer
582 people viewed this question
Ekse
Marvin
Marvin
