SOURCE: LG 50" plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
SOURCE: sound yes, but no picture on tv
If you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then it's one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
SOURCE: LG 50PX4DR plasma tv
I had the same exact problem as posted above. My 50" LG plasma was out of warranty for 1 year! I called the LG executive call center, and they were very helpful. They offered to pay for the parts and labor. They recommended a few local repair shops, and they set everything up for me. The tech came out within 4 days with one part. The tech had to come out one more time the following week, since more parts were needed for the repair. The Y sustain board, along with 2 adjacent parts that are required to be replaced as a set, and the power supply had to be replaced (parts alone cost just over $900). TV is like new again; I'm very happy with how LG handled it, and made what could have been a bad experience a good one.
SOURCE: my 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
my 36" rca green light blinks 3 times, no picture or sound
SOURCE: No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
