Question about Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner
Rimage 2000i error code 7551
Printer is stalling after printing had been finished. Drawer has opened, disk
has been lifted and then all functions come to a stop. Lower orange light is flashing. This problem is happening after about 6 disks. Screen saver is switched off. Help!!
Posted by david1949 on
5 Related Answers
RimageCorp
Casey Neuharth
  • 18 Answers
SOURCE: My Rimage 2000i will not begin production of cd
Hello B13Designs,
If you receive a "No Production Server Active" message when using QuickDisc, make sure that the Production Server status is set to Active, Processing orders in Rimage System Manager. Once the Production Server is set to this status, jobs can be processed.
1. Open Rimage System Manager.
2. Select Production Server. Production Server status information displays in the right panel, next to the Production Servericon.
3. If Production Server is paused or stopped, press the play button. Production Server starts.
If this does not fix your problem, feel free to give our support line a call @ 1-800-553-8312 (Option 2).
Thanks!
Posted on Nov 19, 2010
RimageCorp
Casey Neuharth
  • 18 Answers
SOURCE: The Rimage 2000i recorder leaves streak marks on
Hello pwilford,
The most common cause for this issue is dirt and dust build up on the pivot tray. The pivot tray is the plastic piece the disc slides across when it is done printing. Clean this really well with some Formula 409 and it should "clean up" your issue.
Posted on Jan 17, 2011
RimageCorp
Casey Neuharth
  • 18 Answers
SOURCE: The burner in our Rimage
Hello pwilford,
The most common failed parts in a system like this is the Hard Drives (not in your case) and the recorders. It is very possible that the recorders are going bad and need to be replaced. If you have a current contract or want to see if you can get one to fix the problem, please call our support line at 1-800-553-8312 (Option 2)
Posted on Jan 18, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: My Rimage 2000i is not
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 08, 2011
prashant2012
Prashant Sharma
  • 1127 Answers
SOURCE: where can i download
Hi
For download the driver please click hear
Posted on Jun 08, 2011
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
Kyocera ps1010 will not print bottom orange light stays on
unplug the network cable turn machine off and then on without the cable plugged in if it comes ready your problem is the print job delete it
Feb 01, 2018 | Kyocera Mita FS 1010 Laser Printer
Orange light flashing five times
With the printer on...
Open the lid
Remove the ink cartridges
Lift the print head lock lever on the left
Remove the print head
Gently clean out any ink
Gently clean the copper contacts on the back
Gently clean the print head nozzle(s) on the bottom
Make sure it's dry
Re-install the print head
Put the lock lever back in the down position
Reinstall your ink
Close the lid
Try printing again
The printer may detect that you removed/inserted ink so it may go through a print head cleaning of it's own that you need to wait to finish
If needed, power cycle the printer and then try printing again
You may need to replace the print head
Nov 11, 2017 | Canon PIXMA iP3500 Printer
How to solve E-2-7 on a canon pixma mp150 all-in-one printer?
Try this ~
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
If still cannot, try this ~
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Hope it helps. Good luck =)
May 02, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
Orange light is flashing 7 times, but printer ,is locked. Ink tanks do not centre when lid is opened.
3. Release RESUME
0 presses - green light - Test Print (exit service for i960)
hope this helps
Sep 08, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The printer flashes orange light five times, and green once
3. Release RESUME
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Error Message on PIXMA 470
try to reset your printer--
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again. this works. thanks.
Mar 09, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
Canon i860 - Service Error 5100 I have tried the reset procedure several times (Resume, then power and hold power, resume 2x, release power) but the light never stops blinking to go on. Any...
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME (while still holding down the POWER)
3. press RESUME twice, then release POWER
4. The green light will blink and the printer will make some noise. Wait until this is finished, you are now in the printer's diagnostic mode.
To select one of the functions below, use the RESUME button and then press POWER to execute:
# of RESUME Presses - Light Color - Function
0 - green - Power Off
1 - orange - Service Test Print: Extended nozzle check pattern
2 - green - EEPROM information print
3 - orange - EEPROM initialize
4 - green - reset waste ink counter (For the Canon waste tank full error)
Remember... ATTEMPT THIS AT YOUR OWN RISK!!!
May 03, 2008 | Office Equipment & Supplies
Stupid printer
Mp150 Reset Counter
Service mode operation procedures -
button pressing
procedures below.
procedures below.
Sep 26, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner Logo
394 people viewed this question
Top Rimage Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
