The outside ambient temp has little effect on the suction pressure. The indoor temp is what will slightly effect the suction pressure. In the trade we say we want a 40 degree evap coil, this means approximately 125psi. This is when the indoor temp is around 74 to 78 degrees. The hotter the house, the higher the pressure. I like to see a 50 degree evaporator when the indoor temp is above 80. Charging by subcooling is the way to go!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Sep 22, 2017
SOURCE: What is a 410A 3 1/2 ton air-conditioner low pressure at 80 degrees
??? 80 degrees ??? Anything below 100 psi is going to start freezing up. 410a refrigerant is approximately 32 degrees at 100psi. Typically a 410a low pressure switch will open at 50 psi.
Posted on May 08, 2017
May 08, 2017 | Heating & Cooling
on Dec 14, 2009 | Heating & Cooling
Mar 02, 2015 | Rheem 12,000 BTU Mitsubishi 13 SEER R-410A...
Dec 02, 2014 | Heating & Cooling
Aug 12, 2014 | Intertherm P3RA-036K Air Conditioner
Jun 05, 2013 | Heating & Cooling
Jul 11, 2011 | Heating & Cooling
Aug 09, 2010 | Whirlwind FH-778 Air Conditioner
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
898 people viewed this question
