Most likely the failure is a microswitch that has failed. Though sometimes a connection or wire can fail, a switch that is often activated on/off will fail more readily. Are you knowlegable in electrical systems testing? If so, I have a troubleshooting chart you can follow. Let us know...
First find out the significance of the code and then knowing what the issue may be you can attempt to fix it.
SOURCE: Whirlpool ADP 5500 dishwasher stops - light flashes 7 times.
It's a heating issue either a bad heater or bad sensor.
SOURCE: whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters?
i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
SOURCE: I have a whirlpool dishwasher ADP 5540 and the top
check botton sprayarm for crack, hole clog up an make sure the tower is under upper sprayarm
SOURCE: fault f6 is flashing on our dishwasher model adp
waters not getting through, or water pressure is low, i think
