Check out the water source to the refrigerator. Re the icemaker - is there water in tray? If so you need a new heater assembly. No ice? - then the water solenoid is not working.
Search Over 2 1 Million Appliance Parts
Sears Online In Store Shopping Appliances Clothing More
SOURCE: icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
SOURCE: whirlpool icemaker not making ice
There are instructions available to repair this problem at www.AnyoneCanFixIt.com. They also sell the part needed to make the repair. Common problem on these refrigerators that were made in about 2005 or later and have the ice bin bucket on the door.
SOURCE: ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
SOURCE: Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
SOURCE: Whirlpool refrigerator leaks water inside
Its a done deal...:) On MY whirlpool MODEL # ETICHMXKBO3 I found the drain hole frozen.. There was some debris and clogged it up and water froze up behind it causing the deck of my freezer to fill and freeze up and cause the water to drain into the fridge. Solution: remove the ice maker(if equipped) remove the rear aluminum cover. I used a heat gun and melted the 1 1/2 of ice build up and softly with a screw driver clean the drain. When drain is visible use scolding hot water until it starts flowing to the bottom tray. I used my air compressor to finish it off....
