Question about Lexmark Office Equipment & Supplies
There is a small heart shaped thing above the a. How do i fix this?
IMB Wheelwriter 1000 By Lexmark
Posted by Heather Vega on
5 Related Answers
Anonymous
  • 328 Answers
SOURCE: lexmark wheelwriter 1000
Check the keyboard connections. Open the top cover and look just below from the top. You will see two ribbon cables. Make sure they are fully inserted. Are any of the keyboard lights flashing?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 26, 2007
Dick O Reilly
  • 3594 Answers
SOURCE: LEXMARK WHEELWRITER 1000
Sounds like a keyboard, if you send it to us we can repair it for about 125.00.
[email protected]
hope we can help you
DickyO
Posted on Mar 04, 2008
Dick O Reilly
  • 3594 Answers
SOURCE: IBM Wheelwriter 1000 by Lexmark
The beeping problem is that spell check is on try code 1.
Pedro;
I'm not sure what your question is but it sounds like you are in caps. Try code C.
DickyO
Posted on May 08, 2008
ibmcollector
  • 13 Answers
SOURCE: character spacing
There is no pitch switch for this typewriter. The only way that you can change the pitch is by changing the printwheel that has the pitch you want. So if you want to type in 10 pitch you have to install a 10 pitch printwheel the same for 12 and 15.
Posted on Mar 20, 2009
Dick O Reilly
  • 3594 Answers
SOURCE: The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Posted on Jan 23, 2010
Testimonial: "Thank you, very helpful."
Why does my wheelwriter 1000 lexmark typewriter makes this hummin sound as though its stuke.
Lube the round chrome rod that goes throught the carrier, Carier is what hold the ribbons and daisy wheel.
Lube pulleys on the belt. You may need to lube the carriage return motor too.
Aug 21, 2014 | Lexmark Wheelwriter 1000 Typewriter
Need lexmark wheelwriter 1000 typewriter manual
Go to lexmark.com, click on support poke around and you should find a free manual.
DickyO
Aug 22, 2012 | Lexmark Wheelwriter 1000 Typewriter
Need a manual and a price on one for a Wheelwriter 1000 by Lexmark, 6781-024 11AWYDS. Is this manual printable online?
Go to http://support.lexmark.com/index?page=content&id=SO4998&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT We sell reconditioned WW1000 for 295.00.
DickyO
Aug 27, 2011 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1000 typewriter has stopped working
sounds like your on/off switch has went. seen this several times.
good luck,
razors
Feb 09, 2009 | Lexmark Wheelwriter 1000 Typewriter
Storing information on the lexmark 1000 typewriter
For the LexMark Wheelwriter 1000 you can only "Reprint" the information you have typed. Once you turn off the machine the "reprint" mode will not longer retain information.
Jan 28, 2009 | Lexmark Wheelwriter 1000 Typewriter
Lights blink and machine beeps
Check the flat connector that goes to the indicator lights the edge of the keyboard sometimes wears into itand causes a reset sequence.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 1000 Typewriter
IMB Wheelwriter 15 Series II 6783-2
Check the connectors from the keyboard to be sure they are plugged in fully, check to see if you are in language mode (light on rt. side of keyboard) CODE "L" ,if these are OK then you probably need a keyboard.
DickyO
Sep 30, 2008 | Lexmark Wheelwriter 15 Series II...
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
