I need to retune my tv to factory seetings after having a new aierial installed . as i have to retune the tv every time i switch it on , i have some channels but others i have to retune
SOURCE: have retuned sagem pvr 6200 and lost BBC1 and 2
The Sagem PVR 6280 is specifically listed as a model which will have problems with the retune. Although the Sagem PVR 6200 and 6200t are not specifically listed as problem models they are very closely related to the 6280/6240 models and share most of the same firmware and software.
See
the address below for a chart of affected models, you'll need to contact Sagem directly on 0845 0900 316 for
either an over the air update or an update DVD depending upon the
manufacturer.
http://news.bbc.co.uk/1/shared/bsp/hi/pdfs/01_10_09_freeview2.pdf
Sorry
I can't provide you with a definite solution but it's very likely that your model is one of those which only Sagem can sort out.
Please return the favour by rating my answer.
Testimonial: "Thank you - I will contact them"
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
SOURCE: after retune no bbc 1 2 bbc news channels tv with
Sounds like you haven't retuned the set correctly. Use the factory settings/ default setting if poss. Look out for too much signal if you are on a booster.
SOURCE: No BBC channels available after retuning Sony Trinitron TV
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
SOURCE: I have a Daewoo DSL22V1WCD combined tv/dvd with
Press the DTV menu button (<<)
Press the Down arrow until you reach Settings
Press OK
Press the Down arrow until you reach Installation
Press OK
Press the Down arrow until you reach First Time Installation
Press OK
