I don't know Swedish.
Since you don't know how to navigate through the settings, i would suggest you to do a full factory reset of the phone and then set the language of your choice. If you are up for it, reply to this message so that i give you instructions for resetting the phone.
Testimonial: "OK, I'm ready to reset phone if you send me steps. I hope it will solve my problem. Thank you..."
I have listed 3 ways to reset the phone.
I am not sure which one will work for you.
Let me know the status one its done
Hard reset procedure #1
1. Turn OFF phone.
2. Remove battery cover.
3. Press and hold the two silver buttons situated just below the screen.
4. While holding those two keys insert the stylus pen into the hole which is right to the battery, under the battery cover for 5 seconds.
5. Phone will turn on with blue screen, and You will be asked to press "Reset" button to hard reset the phone.
Hard reset procedure #2
1. Turn OFF phone.
3. While holding "Volume Down" key power ON phone. Phone will turn ON in bootrom mode. Screen will be like rainbow.
4. Press and hold the two silver buttons situated just below the screen.
5. While holding those two keys insert the stylus pen into the hole which is right to the battery, under the battery cover for 5 seconds.
6. Phone will turn on with blue screen, and You will be asked to press "Reset" button to hard reset the phone.
Hard reset procedure #3
1. Turn OFF phone.
5. While holding those two keys power on phone.
SOURCE: I cannot find how to change language frm swedish to english
Assuming that all the text is inSwedish and you can't understand it then follow these instructions. Using 'PANEL' button(X at bottom left) on front facia select the top left Panel (black screen with XPERIA written accross the bottom) now select windows logo(top Left)at the bottom of the list should be a 'blue circle with a question mark in the middle of it', immediatley above this should be the 'Settings' folder - select this. You should now have icons(pictures) with 3 'Tabs' along the bottom of the page - select the middle one ( this should be 'system') now look for a Globe (picture of the World) this should be 'Regional Settings' - select this. From the drop down menu select 'English' and whatever regional dialect you want, when you have done this tap top right corner, this should be OK until you are back at the Main Panel, now shut down and then restart X1, you should now have everything in English. Good luck.
