SOURCE: Deapth Of Field
yes, use manual setting and stop down your aperture setting. This was probably f/2,8 or even 2,0. You'll need more light though or other wise a slower shutter speed to compensate for the more closed down aperture. This is a standard issue with macro and worse off with digital due to the inherent relatively narrower DOF that comes with a small image sensor.
SOURCE: Calculated field in Excel pivot
Count will only work with numbers. So select another box where you want your number and use this formula: =count(x:x) This should give the count number then you will need to find the difference. In another box, use =sum(x-x). This should give you your difference.
If this helps you, please rate me. Thanks, Patty
SOURCE: olympus om-2 cvamera lenses
You are able to use your old OM lenses with a new Olympus digital SLR camera. You will need to purchase an MF-OM 1 lens adapter to be able to connect these lenses to the digital SLR camera. Also when using these lenses you will only be able to use the camera in manual focus mode as these lenses are not capable to shhot with an auto focus mode.
SOURCE: Olympus OM-4 stuck shutter
This is very common on many OM SLRs and is caused by dirty shutter magnets. If you look on the web you can find details on how to do this yourself, but as the OM-4 is top of the line I'd highly recommend getting it done professionally as part of a CLA (clean lubricate adjust) service. Last time I had it done in the UK it cost about £80 and when I had it done to my OM-2SP in the USA last year it cost just under $100.
SOURCE: Nikon FA depth of field preview lever sticky
The small lever on the inside of the mirror box is what controls the aperture. If the lever on the outside is sticking, it would only hold the lever on the inside down so you would be stopped down all the time. You can try a small amount of lighter fluid at the base of the outside lever and work it back and forth to see if it would free up.
