Question about The Kitchen Appliances - Others
The air fryer is not getting hot and not cooking the food
Posted by Josephine Fierro on
kim atchison
    Habit-Forming:
    New Friend:
  • 64 Answers
This may be a simple fix, or it may be time to get a new air fryer. First, check to make sure everything is properly connected and your circuit breaker is not blown. Then, check the timer to make sure it is not set yet. Sometimes, air fryers do not turn on if the timer is in the middle of a cooking session. If none of these solutions fix the problem, it is time to recycle your air fryer and upgrade to a newer model.
Posted on Sep 21, 2017
5 Related Answers
Anonymous
  • 700 Answers
SOURCE: Oven not hot enough
the thermometer is most likely the problem, the calibratation is probably off. If you have access to a accurate digital thermometer it is relatively simple to do. If you do have one just take and set the knob to 250 degrees and when the oven gets to 255 it should go off and come back on at 245 degrees. If it's a digital there shopuld be a potentiometer that you have to adjust. good luck
Posted on Dec 26, 2008
Anonymous
  • 71 Answers
SOURCE: it won't get hot no more won't get hot at all it
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Posted on Sep 16, 2009
bosch guru
  • 457 Answers
SOURCE: mircowave turns on but does not cook food
you have a bad magnetron . that is the heating source . the part is not cheap. go to sears parts direct and check out the price b4 you have someone check it.
Posted on Feb 27, 2010
Peter Hampton
  • 193 Answers
SOURCE: i recently purchased this deep fryer i didnt even
did you press reset button
Posted on Apr 23, 2010
kebah
Angel Joseph Jr.
  • 684 Answers
SOURCE: I need an operator manual for my rival CF105 Cool
Try to search manual at http://www.rivalproducts.com
Regards.
Posted on Jun 25, 2011
Is my fan supposed to run while the air fryer is cooking. I can’t get mine to come on
an air fryer uses a fan to circulate the hot air
without the fan , it will not work properly
Nov 28, 2017 | The Kitchen Appliances - Others
I have read the owners manual and it does not say how much water and oil to put in, need help?
You do not put water or oil in an air frier As the name suggests it uses hot air to cook food, If you cook home made fries then I suggest you boil the fries for a few minutes (depending on thickness ) then pat dry and put a light spray coating of oil on prior to Air frying.
Oct 13, 2017 | The Kitchen Appliances - Others
Cook's essential air fryer doesn't turn on. Have to push basket/food holder in and out and sometimes it works. Help
it aint gonna run on until shut so check make sure nothing is in there to stop the complete closing of the machine is what I would try
Dec 29, 2016 | Kitchen Appliances - Others
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
Do you cook food with the lid on
Yes always keep the lid on when possible to keep it from splashing all around and to keep the oil hot...
heatman101
Sep 04, 2010 | Russell Hobbs RHGDF14 Deep Fryer
Deep Fryer doesn't get up to a proper temp.
9 TIMES OUT OF 10 THE TEMPATURE DIAL ON ANY DEEP FAT FRYER IS NOT FULLY ACCURATE TO MAKE SURE YOUR FOOD IS PROPERABLY COOKED YOU WOULD HAVE TO LEAVE IT THAT BIT LONGER
Jan 09, 2008 | Rival CF275 Deep Fryer
Kitchen Appliances - Others Logo
192 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
