Question about Lite On Computers & Internet
No sound comeing out next to volume control yellow lite on says overloaded
Posted by Michael Gentner on
Brant Kingery
    New Friend:
    Problem Solver:
  • 14 Answers
Rule number 1 in pc troubleshooting and electronic troubleshooting is to always power down the device and turn it back on to see if that doesn't help, if the problem persists. . . you can call us on your fixya app and we can help you fix your issue with no problem. Hope this helps ??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brant_4c68df22dda524c2
Posted on Sep 21, 2017
1 Related Answer
freetek
Steve Allison
  • 5569 Answers
SOURCE: no sound
You will have to download the driver from the mfr.'s website. There are other sources but often they do not have the most recent version.
Posted on Aug 23, 2009
My technical sug90 stereo has no sound and next to volume control yellow lite on says overload
Could be caused by a faulty speaker or cable. Make certain that all speakers and wiring is good. Then disconnect the unit from the mains and try again.
If the light does not go off the circuit is either faulty or there is a power amp fault.
Sep 21, 2017 | Audio Players & Recorders
No sonund coming out ,one yellow question marks are there in device mnager
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 24, 2011 | Computers & Internet
No sound after format
hope this helps
Jan 19, 2011 | Creative Labs CT4870 / CT4780 Sound Card
Sound driver
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Oct 26, 2010 | Soyo P4X400 Dragon Lite (P4X400DRAGNLITE)...
No sound when computer is being shut down or playing music on windows media player. button next to power button not lite up. push mute button back off still cannot get a sound.
Check the volume controls and sound properties. Make sure that the master volume ins not in "MUTE".
Double-click the speaker icon on your tool bar. The volume controls will appear.
Check the Sound properties:
Right-click the speaker icon > Adjust Audio Properties:
Audio tab > make sure to select the right sound device.
Thank you and good luck!
Sep 12, 2010 | Dell Latitude D600 Notebook
My computers sound is not coming
Make sure that you check the cables are connect it on the right port on the back of your computer. Next check the device manager to see if the driver is not install properly. If there are no yellow marks next to it you should be find. Opend the sounds panel on the control panel and check that volume is high and not mute
May 25, 2010 | Dell OptiPlex GX260 PC Desktop
Sound problem
Check taskbar volume control and make sure its max. If you have volume buttons make sure they are maxed. Some laptops are a key combo to increase/decrease volume. Make sure whatever program you are running that the volume slider is all the way up. Go into your control panel and double check your volume settings. Go into your device manager and make sure there are no exclamation points in yellow next to any audio devices or codecs.
Mar 09, 2010 | Toshiba Satellite Pro A210-EZ2203X...
Power lite is on but nothing happens when power on is pushed
Check your Speaker control button. Most receivers have a small button on the front used to control your choice of Speaker Set A, B, A & B, or NONE. It's possible you have inadvertently pressed the button and set it to where no speaker set is selected. Therefore, no sound.
Another probable cause is that one of your speaker cables may have become dislodged at the back, and if your system has an overload control mechanism, it's preventing sound to come out to avoid damaging your output transistors, your speaker system, or both.
The last (I hope not) possibility is that the volume may have been cranked up too high, that either the output resistors may have blown on your receiver, or your speakers may have given out the ghost due to too high a signal.
Aug 17, 2009 | Aiwa AV-D57 Receiver
Audio driver instalation
Here is a list of things to try:
Note: Start with #s: 6, 7, and 9
1. Uninstall and reinstall the sound drivers
2. Install K-lite codec pack http://fileforum.betanews.com/detail...d/1094057842/2
3. Start > Programs > K-Lite Codec Pack > Configuration > Codec Tweak Tool and check the box next to [Registry] Fix non-working system sound
4. Make sure the volumes are not set to zero and that nothing is on mute Control Panel > Sounds and Audio Devices > under Device Volume, click on Advanced
5. Make sure that everything in Device Manager is fine (no yellow or red marks) Control Panel > System > Hardware tab > Device Manager
6. fixnoflashsound.reg (just click on the link and install it) http://files.filefront.com/fixnoflas.../fileinfo.html
7. netvol.reg (use Internet Explorer to click on the link and install it) http://www.kellys-korner-xp.com/regs_edits/netvol.reg
8. If possible, make sure Digital Output Only is not check marked (not all cards support Digital Output Only) http://tomebling.home.comcast.net/~t...oundConfig.jpg
9. Confirmed the presence of msacm32.drv and msacm32.dll
Search for these files in C:\Windows\System32
If you don’t have it, download it from here:
http://www.filesavr.com/msacm32
Made sure speakers are properly connected to sound card
Run SFC /Scannow
Start Menu > Run > type this in exactly (note the space between C and /): SFC /Scannow
Tried different Video player
Installed Quicktime Alternative
Reinstalled DirectX
Confirmed presence of "plug and play software device Enumerator"
Made sure that default devices were selected
Control Panel > Sounds and Audio Devices > Audio tab
Tried using different settings in the sound card’s configuration window
Installed Microsoft ADPCM Audio Codec and IMA ADPCM Audio Codec
for %x in (C:\WINDOWS\System32\*.dll) do regsvr32 /s %x
Thanks
Aug 09, 2009 | Intel D945GCNL Motherboard
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
Computers & Internet Logo
Top Lite On Computers & Internet Experts
Vernon Taylor
ray gallant
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
