Reset power button on power strip first turn off then on.If that don't work check and see if it is a switched outlet turn wall switches on in area.check and make sure cord is secured to scanner. Plug a lamp that is on in the strip this will help you when you are trying to turn switches on by yourself you can see it light up.
SOURCE: lost book to scanner its
do you have a button marked "prgm"
if not, then push the manual button until it
gets to the channel you want to program,
then enter the freq ie... 155.xxx and hit
enter, don't forget the decimal point .
http://www.uniden.com/index/manuals_results.cfm?cat=3
heres a link to uniden bearcat manuals , but i don't see yours .
but my instructions will get the job done .
SOURCE: Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program.
Note the channel in the display. If there is a hyphenated symbol in the
upper left corner the channel has been locked out. Press the LOCKOUT
button once to remove the symbol or press the LOCKOUT button to lock a
channel out. To find out if there is a frequency programed into that
channel, press the PREVIEW button. Each digit of the frequency that is
stored in memory will be displayed in the LED display. To program a new
frequency into that channel, simply press the digits of the frequency
you want, including the decimal point. Press the "E" keypad key to
enter it into memory. If you get a "E" displayed in the LED display,
the frequency was entered wrong, is not a valid frequency or is out of
range for the scanner. Last but least, the scanner is not working
properly. If the channel is active, (communications going over it) set
SQUELCH to higher number, until you hear the communications or just
noise. To set the SQUELCH, select a channel that has only noise and
turn it down to the point the noise disappears. You make have to
readjust it to your liking. Once you have the channels programed you
can select the SCAN button to listen to all the channels or select the
MANUAL button to listen to just one channel. If there are channels that
you don't want to hear during the scan mode, go to MANUAL and select
the channel you don't want to hear and press LOCKOUT button. Then press
SCAN again it will only scan channels you want to hear.
Hope this helps.
SOURCE: uniden # bc145xl scanner
hi my uniden bc145xl has just lost sound it still scanns fine just no sound is there a fuse or somthing to replace because when it quite there was smoke coming out the ext. sp hole
SOURCE: I need instructions on how to program a Uniden
Most older Uniden scanners can be programmed in these five easy steps:
1. Press Manual 1 Manual (should be channel 1)
2. Enter a frequency
3. Press E
4. Press Manual to advance to the next channel
5. Repeat steps 2 to 4
If you want a manual, apparently you will have to buy one... Price is $6.00 (including shipping) unless otherwise indicated Old Owner's Manuals Available
or Bearcat Manuals from Vintage Manuals, Inc. I am not affiliated with either, and did not check whether they have your model.
