SOURCE: I can't get my neetle tensions tight enough on my brother overlock machine
First thing is to make sure there is no lint etc caught in the tension unit, even a small amount can reduce tension considerably.
If that doesn't solve the problem, we need you to give more detail of the machine, as there are a couple of different tension units which require different methods, 'over the top' or 'around a knob' ........which of these two is most like your machine ?
If you want any more help with this, post back to here, or just drop a line through the "Contact Us" page at www.bargainbox.com.au
SOURCE: Spares for Brother Overlocker 925D
Here is the brother serger part you are looking for:
http://sewingpartsonline.com/needle-plate-brother-925d-serger.aspx
SOURCE: needle getes broken
Check to see if your needle plate is gouged or signs that the needle is hitting the plate. If so, you may be pulling a little too hard when the fabric is feeding. Sometimes when you pull too hard, it pulls the needle back and it will hit the plate instead of going into the needle hole and you will break needles. Try just letting the fabric feed itself and you simply guide it to make sure it stays in a straight line.
SOURCE: I have a 523n brother overlocker just broke the
went down to a shop with the broken needle and replaced it with new one ,thanks for replying.
