Question about Dewalt 7.2-18.0 Volt One Hour Charger
No Manual? My new DW9116 1 hour charger arrived yesterday. It clearly says on the front to read the manual for information on the tune-up mode but there's no manual with the unit and there's no manual posted on the DeWalt site!
Posted by Whatsisname on
  • Whatsisname Dec 26, 2007
    unfortunately, there is not button of any kind on the chargers. This may have been a feature on older versions. According to the manual- which I got to read by finding a store that had them in stock and the fellow there helped me open up a box and get the sheet out to look it over - the tuneup feature kicks in automatically if the battery is left in place for more than the charging time and takes 6-8 hours to complete.
CitizenKane
Online Manual (PDF) For DW9116
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/630429-00,DW9116.pdf
Dewalt DW9116 Product Recall:
http://www.dewalt.com/us/articles/article.asp?ID=187
Posted on Apr 07, 2009
Anonymous
    Problem Solver:
  • 4 Answers
The tune up mode on these chargers is a three stage charging process which helps to prolong the life and endurance of you batteries . to put the charger into tune up mode all you have to do is press the yellow button on the back right hand corner of the charger , when the batteries is being charged in tune up mode the charge time in considerably longer than the normal 1 hour charge time .i would recommend to use the tune up mode at least every 4 - 5 chargers to maximize the the life of your battery's .if you are not using the battery's flat out all the time it will not hurt to use tune up all the time. I hope this gives you a good insight into the operation and care of your battery's and charger.
Posted on Dec 25, 2007
Anonymous
    Problem Solver:
  • 6 Answers
Hi Whatsisname,
I also brought this charger today without an manual and am trying to search for the manual to see how to activate the tune up mode. Thanks for the answer. :)
Posted on Dec 30, 2007
Buzz Lightyear
    New Friend:
    Problem Solver:
  • 5 Answers
Jan 31 2013.
This link will deliver the Dewalt manual for charger #9116:
http://servicenet.dewalt.com/Products/Detail/DW9116#
The unit was recalled and is discontinued, but you can still buy them on the net.
The replacement model, #9310, is more expensive.
I have no opinion or experience, whether the older 9116 works as well to maintain and condition batteries, but both models are SUPPOSED to be dual NiCd and NiMh capable.
Posted on Jan 31, 2013
Anonymous
Go to www.dewaltpowertoolsonline.com and select
any of the battery powered tools and they have
battery charger instructions included
Posted on Apr 17, 2008
Setting my timex to regular time mode
Hello Christie Thomas,
Without an actual MODEL NUMBER...
I can only offer that Timex OWNERS MANUALS
(EASILY found on manualslib.com)...
are the quickest & best source of information...
(like model T231 uses the "TUNING" arrows
to adjust HOURS/Minutes.. See here)
Timex T231 User Manual Controls And Indicators
Hope this helps
Carnac the Magnificent
Mar 13, 2018 | Timex Watches
I need a manual for nako NA-823a
NAKO NA-823A Instructions
Turn Alarm on or off:
-Press the S and D buttons simultaneously
Display Date:
-Press the D button
Set time and date:
-Press the M button to switch modes in this sequence: stop watch>set alarm>set time>time.
-The S button will allow you to select seconds, minutes then hour, then day, month and weekday.
-Use the D button to clear seconds to zero, or move minutes and hours and date up by a single increment.
-Press and hold D for two seconds to move minutes and hours rapidly.
-Press and hold D while pressing and holding S moves through AM/PM and 24 hour (H) modes.
Use stopwatch:
-Press the M button until you arrive at the stopwatch.
-Press D to start and stop
-Press S to clear.
Jan 14, 2013 | Televison & Video
Hi, Yesterday the system arrived home and I
Look at the notes on page 22 in the manual. It may not be the settings just don't match up with the TV. It takes two to tango.
"Resolutions available for the HDMI output are 480p, 720p,1080i/1080p. See page 27 for the resolution setting.
This product operates in Interlace scan mode 480i for component/composite output.
After making the video connection, set the Video input source on your TV to match the corresponding Video output (HDMI, Component or Composite) on your product.
Turn this product on first before you set the video input source on your TV. See your TV owner's manual for more information on how to select the TV's Video Input source."
What does your unidentified TV manual say about the message?
Jul 01, 2011 | Samsung HTC550 Theater System
Have GE digital timer 15117. Can't figure out how to make the display show AM/PM so I can set it correctly. Clock hour/min just cycles through 12 hours without noting AM or PM setting. Can't program...
GE 15117 manual
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
You might try a new AA battery.
Some guy wrote in this week and said he bought 6 timers and all the batteries were bad except 1.
Some timers, like Woods TD1300, and others have the 12 hour or 24 hour option.
You press and hold Time button to choose 12 hour or 24 hour
But GE 15117 manual says nothing about this option.
GE 15117 timer is same timer as Woods 59403
Several folks have written in past couple weeks about the Woods 59403 timer skipping over functions.
The best I can guess is your timer is malfunctioning like the other people's timers.
Woods 59403 manual is identical to GE manual, and says nothing about 12 hour 24 hour option either
http://waterheatertimer.org/pdf/Woods-59403.pdf
I test timers for programming and wiring difficulties.
Yesterday 3 timers arrived here, and 1 didn't work.
I took it apart and tested the electronics, and something went bad.
When these timers don't work, you get your money back or throw them away.
Dec 04, 2010 | GE Hardware & Accessories
Replaced the bulb yesterday- the projector does not recognize the change- getting a default message to change it... And there is a strange smell (we also changed the filter (after 5 yrs)
copied from manual
select the menu - default - clear lamp hour meter to reset lamp usage hours.
Note when the lamp exceeds 2100 hours (3100 in Eco mode) the projector cannot turn on and the menu is not displayed if this happens do the following while in 'standby' to clear values for Remaing lamp Time and lamp hour meter for vt670/470 press the help button on remote control for a minimum of 10 secs When the lamp clock is reset to zero the lamp indicator goes out.
May 14, 2010 | NEC Replacment Lamp Projector Lamp for...
Stove reads s ab
"SAB" is the Sabbath Mode. This enables the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
I believe your model number actually reads "AER5725QAN" This is the closest match I could find for the model number you provided. The instructions for Sabbath mode are listed on page 12 of your owner's manual. To cancel Sabbath Mode you press and hold the CLOCK button for 3 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please post back with your correct MODEL NUMBER (if different from the one I provided) and let me know. I hope this helps you.
Apr 22, 2010 | Kitchen Ranges
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
I have a Kenwood KDC-W311A car radio/cd, and am having problems setting the preset stations. It insists on doing an auto search and whizzing thro' the frequencies @90 mph. I know there is a way to do a...
Apparently there are 2 modes in which to use the MENU function, Standby & Tuner mode. The manual doesn't make this very clear. However, Manual Tuning can be aceived by putting the radio into TUNER mode, then pressing the MENU button for a couple of seconds & scrolling thro' with the Control Button until you can set Manual Tuning to ON.
1chab0d
Apr 08, 2008 | Kenwood Audio Players & Recorders
Dewalt 7.2-18.0 Volt One Hour Charger Logo
2,526 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
efs_perpends
efs_perpends
Mike
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
