Question about Bravetti Kitchen Appliances - Others
I need a break away power cord for a bravetti mod # F1100H
Posted by Joe Florence on
4 Related Answers
Anonymous
  • 124 Answers
SOURCE: I have lost the power cord and cannot find a source for replaceme
This product was manufactured in China for Euro-Pro and your power cord is available for that model. Just go to the following website: http://www.euro-pro.com/europro/default.aspx. Type in your model number in the parts search on the left side of the page. Your power cord is available for $9.95 plus s/h. I hope this information was satisfactory and please visit fixya.com again.
Posted on Jan 26, 2009
farfield
Farley Redfield
  • 462 Answers
SOURCE: bravetti 8l deep fryer f1100h
Either there is insulation missing or misplaced is my first thought. Then if that's not it how is it vented and if there is a leak on the "Hot Gas" from the combustion (assuming you have gas not electric and if electric believe Id be looking at the wiring for bad connections creating excessive heat or wrong type wire not approved for high heat installation).
If this helps you please rate me as high as you can thank you you for using fixya.
Posted on May 06, 2009
Jeffrey Robertson
  • 43 Answers
SOURCE: NEED A POWER CORD FOR BRAVETTI FLASH FRYER
Euro-pro.com for parts and manuals.
Posted on Jul 04, 2009
Anonymous
SOURCE: Need a break away power cord for the 3.5 Quart
Need a break away power cord for the 3.5 Quart Deep Fryer model # RHDF260A. Where can this cord be purchased?
Posted on Oct 11, 2010
How do i find a power cord for a Bravetti 8qt. flash fryer
You may be able to find a replacement at this site:
Where can you get Euro Pro replacement parts
or
http://www.ninjakitchen.com/customerSupport/cooking
or, you may be able to take the unit to a hardware store and see if they have a power cord that will work. Doesn't look like Bravetti is a common brand (may have been phased out).
Jul 16, 2016 | Bravetti Kitchen Appliances - Others
Jul 19, 2010 | Russell Hobbs RHDF260A Cool Zone Deep...
Need a plug in cord for a bravetti platinium pro fryer 2 prong
Where can i buy a magnetic break-away cord for a Bravetti F1075H Deep Fryer
May 28, 2010 | Bravetti F1075H Deep Fryer
No power
It could probably be repaired, just find a new line cord or just cut the old one down a little. By no luck soldering, will the solder not adhere to the copper? try using rosin core solder or flux. and about 700* solder iron temperature. if you need anything else post another question
Apr 05, 2009 | Bravetti 35-396 Power Hand/Stand Mixer
Jan 26, 2009 | Bravetti K4320H Deep Fryer
Break away power cord 3 liter stainless steel deep fryer`
Keep the connections clean where the plug meets the probes. You may have to prop up the plug so that it won't fall off or disconnect. Unfortunately, this is a poorly designed model and should have never gotten a UL label.
Jan 25, 2009 | Bravetti Kitchen Appliances - Others
Bravetti 8l deep fryer f1100h
Nov 13, 2008 | Bravetti F1075H Deep Fryer
Kitchen Appliances - Others Logo
Top Bravetti Kitchen Appliances - Others Experts
Mike
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Bravetti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
