SOURCE: i lost my user manual and the VCR remote control how do i access the menu from the VCR?
look for user manuals at http://www.user-manual-search.com
SOURCE: Need menu control
On some tv's holding down one or two of the buttons on the front of the tv for a few seconds will bring up the menu. If it comes up you can probably navigate in the menu with the buttons on the front of the tv.
SOURCE: No Remote - Need to access Menu
on some sets you can push both the channel up and down buttons to access the menu, then use them and the volume buttons to navigate the menu. otherwise you may have to get a programmable remote control.
We had the same problem - this worked for us:
1. Unplug TV
2. Press Channel up and Volume up at same time, while plugging TV back in (two person job - it will pull up a service screen)
3. Press Channel up and Chanel down at same time. (Access to menu screen)
4. Use Volume up and Volume down to switch between menu options. We finally found the EZ set up screen.
Somehow in the process we muted the TV and are now working on getting the sound back. :)
Good luck to you!
SOURCE: I lost Orion 13" Model TV1318 remote.Need to menu button access
you can purchase a advanced universal remote or you can go through the menu manually on your set
