SOURCE: VIZIO 50" PLASMA
Wow. This is more comon than I thought. My 50" Vizio plasma just went out as will after a loud pop noise. Power button is still lit. Sound continue to come through but no picture. I will dig into it and see if I can find a appropriate solution.
SOURCE: Loud Pop Vizio P50HDTV10A 50 in.
Just to add to the above post it can also be popped Ceramic fuses. Its worth a try. In most sets I fixed there are about 6 of them and cost you about 10$. Check the specs on the fuses and get the same ones. Pop the old ones out and the new ones in and see if it works.. If it doesn't you have to get a new PS board as WeListen2You has suggested.
SOURCE: 50" Vizio sound but no picture
those plasma hove a lot of problems with the y-sus board signal board take you meter check cops ics. was it flashing black and white before you replaced the boards
SOURCE: I have a Vizio E500i-AD that has power but no picture or audio. What should I replace to fix this.
There is no one part that causes this, you have a defective/shorted circuit board, you need to do some testing based on the factory repair diagnostics.
