Question about Sharp Cameras
When trying to recharge the sharp VL-A111H viewcam a red light shows which begins flashing.Is this due to battery malfunction
Is the simple solution..change the battery ?
    Top Expert:
  • Sharp Master
  • 85,223 Answers
Yes it is due to a defective battery
Posted on Sep 19, 2017
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: NEED A MANUAL VL-A111H FOR THE SHARP VIEWCAM
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Posted on May 31, 2010
May 31, 2010 | Sharp VL-A111 Camcorder
The red light flashes when its charging
Had this problem myself and found that the voltage of the battery was too low for the camera to charge (2.8 volt,s)
I manually charged the battery up past 3 volt,s then put it back in the camera and plugged it in--the light did stop flashing and did finaly turn green.
Or just get an external charger online for cheep.
Oct 24, 2009 | Sharp Viewcam VL-AH50U Hi-8 Analog...
Bypassing of DEW sensor
there is no way to bypass it, but simple modification is available to correct this problem. contact any sharp authorized repair center.
Sep 13, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Ihave a view cam made by sharp and the model #vl-ah160 and it does not hold its charge even wih new batteries.i had drop it and i was wondering if this can cause it fo not holding a charge
if it still works ..I dont think this should have cause any problems ....I guess the power issues came from poor quality of the accumulators or better from a not that great formating of them when they were brand new....another cause may be the age ...after all even in mobile phones , those rechargeable ones have a limited life time ...and his is the way they behave .....I mean they begin to last less and less.. a solution might be new ones...or even try to never let them inside the camera even when the power is off...cause all cameras empty them batteries when they aren;t even on ...
Sep 10, 2009 | Sharp Viewcam VL-AH160U Hi-8 Analog...
Sharp Viewcam VL-AH151
is there any easy way to tighten up the swivel mount battery compartment?
Oct 06, 2008 | Sharp Viewcam VL-AH151U Camcorder
Battery charge
I'd start there. Usually the flashing red indicates that the charging function is not working. A defective battery can cause this.
Dan
Jun 10, 2008 | Sharp Viewcam VL-A10U Camcorder
Sharp view cam vl a10
my view cam is blury when you try to play any movies on it.
May 31, 2008 | Sharp Viewcam VL-A10U Camcorder
Vl-Z1 Viewcam
First I have to say it seems you have a small connection problem... try changing the charger for another one or your connector . 10V with and adapter heads at Walmart for $9 dollars. Then see if it's the actual charger.. if that fails then you know it's the connector on the video camera and you can bring it for repair to a local fix it place those parts are cheap and easy to change. Takes about 20 minutes to change.. and thats after having a cup of coffee for 5 minutes.
I personally would buy a seperate charger for $29.99 and just have a rapid charge of 30 minutes for each batterie lasting 2 hours afterwards... Shower and shave and it's all ready.
Jul 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
The "DEW" indicator is illuminated on my Viewcam, what do I do to turn it off?
This means there is moisture inside the Viewcam. Try taking the tape out, leaving the cassette compartment open for 2 hours to allow any condensation to evaporate. If the DEW indicator is still illuminated call a Sharp authorized servicer.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Cameras Logo
Top Sharp Cameras Experts
Marvin
Marvin
tylerbell49
Level 1 Expert
NOEL
NOEL
Are you a Sharp Camera Expert? Answer questions, earn points and help others
