Question about FUJIFILM Cameras
I have a fujifilm exr 30 and when it is set at S I cannot get the aperture higher than f 4.5 can anyone help Thanks Joan
I take outdoor rugby so my shutter is 500 and my ISO is about 400
Posted by joan on
Tony Parsons
  • FUJIFILM Master
  • 6,298 Answers
The answer is probably in the manual
Posted on Sep 19, 2017
5 Related Answers
Anonymous
  • 551 Answers
SOURCE: F828 and ISO question
If you're in shutter-priority mode, yes, the shutter speed will increase. If you're in manual mode, it won't do anything until you set it manually. Just remember that, for any given exposure, shutter speed and f-stop are inversely proportional. Higher fStop, lower shutter speed. Lower f-Stop, higher shutter speed. And that the higher the f-stop, the smaller the aperture. On the F828, f2.0 is largest aperture (most light), f8 is smallest aperture (least light). ISO, on the other hand, is an approximation of film speed. In reality, however, raising the ISO just amplifies the signal downstream from the sensor - but the net effect is the same as lowering the f-stop (bigger aperture), which allows you to have a faster shutter speed for the same exposure. Hope this helps...
Posted on Sep 12, 2005
Anonymous
  • 3 Answers
SOURCE: On my Finepix S9500 when
Sorry, not a solution but wondfered if you ever solved this because I cannot work it out!
Posted on Nov 22, 2009
Anonymous
  • 571 Answers
SOURCE: tell me something about settings of outdoor
Put the camera on auto and it will set all those for you. By exprimenting you'll find the right settings for each occasion. To perfect this may take years. The settings depend on the weather, clouds, buildings nearby, water, target (moving/stationary/speed etc.).
With digital camera it's easy to take pictures with different settings and immediately be able to compare and find the right ones.
Posted on Nov 30, 2009
Ty Price
  • 11967 Answers
SOURCE: 1- How do you set ISO?
The ISO is set in the camera menu. You can't set the aperture and shutter manually...this is basically a point-and-shoot camera with some nice features. You should copy the disc to your computer and then open it from there by double-clicking on it.
Posted on Apr 05, 2010
Geoff Hone
  • 71 Answers
SOURCE: Pictures a very overexposed. Inside
Have you set the 400 ISO, or do you have the camera on Auto ISO?
Go back to your setup menus and set the Sensitivity to the lowest ISO value possible.  Now set the White Balance to Auto. Exit the menus.
Now set the camera to P for program. In effect, you have turned the camera into a point-and-shoot dimwit. It should now take reasonably well exposed shots indoor and outdoor.
If the shutter speed does not register on the body, you should put the dial on Tv and see if you can alter the speeds.  Remember, not all finctions are available for all dial settings.
Posted on Jul 26, 2010
Factory reset
there is only a normal reset mode, it is on page 93 of the manual. The manual is free on the fujifilm site. Just google for fujifilm and HS20 EXR manual.
Sep 26, 2013 | FUJIFILM HS20 EXR Digital Camera
Fujifilm Finepix HS25 EXR screen replacement
Your best bet is going to be E-Bay, search your camera make and model under parts and you will find just what you are looking for.
Jan 23, 2013 | Fujifilm FinePix HS25 EXR 16MP, 1080p 30X...
How do i put my fujifilm finepix s 200 exr back to factory settings
To set the camera back to factory settings first go to Setup Menu Options> Reset
See diagram
Hope this was a help Happy New year
Dec 31, 2010 | Fuji Cameras
Casio S600 Exilim takes outdoor overexposed pictures
Check the ISO ( film speed (ASA) that you have set change it to either 100 or 200 and even 64 if it allows that.
You need to have the shutter snap fast in sunny/bright conditions and the Aperture needs to be a large number like F11
The higher the number the smaller the aperture ( sharper image not bleached out) F4 can be too large so can F8 in many cases and will, combined with the wrong ISO ..overexpose your pictures.
Please rate the help ++++Thanks for using FIXYA
Sep 26, 2009 | Casio Exilim EX-S600 Digital Camera
Focusing
You'll have to set the aperture to a higher number. Set camera to Aperture Priority mode and increase the number (usually set at 2.8). The higher numbers will preserve foreground and background focus but will require more light - not a problem in outdoor daytime but at night or indoors will need flash.
Jun 17, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Dark exposures
This could be many things. If indoors, use higher iso setting and/or use the flash. Make sure exposure compensation is set to 0, or raise it. Use one of the automatic programs and let camera pick shutter speed and aperture. In manual mode, pay attention to exposure value in viewfinder, and avoid using higher apertures unless outdoors in bright sun (f16, f22, etc) the higher this number the less light is allowed to camera.
May 04, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Aug 06, 2007 | Polaroid i832 Digital Camera
Cameras Logo
Top FUJIFILM Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
