SOURCE: Lost installation disk
Download the driver package that suits your operating system (XP, Vista, 2000) from Lexmark. You will find the files here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:462:0:0
For future reference, entering just p6250 brought up nothing at Lexmark's support site. Enter Lexmark p6250 & it goes right to support for your printer.
Hop
SOURCE: I HAVE A LEXMARK ALL
You can download the driver here, directly from Lexmark:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+P6250
Be sure to unplug the printer from the PC before installing the software, and only plug it in once the on-screen instructions tell you to do so.
SOURCE: Install CD for Lexmark P6250
I have bought a new computer & I need the CD to add my Lexmark P6250. Do you know the weeb site I would go to. I have XP. Hope to hear from you soon. Thanks
SOURCE: how do I clear carrier jam on lexmark p6250
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
SOURCE: lexmark p6250 installation windows vista
Go here and type in your printer in the search box. Click on Vista, then download the file and run it. This will install the vista drivers for your printer.
Thanks and please take a moment to rate as fixya.
