Question about Minolta Office Equipment & Supplies
Minolta 6001 Question about err0r code f30 - Minolta Office Equipment & Supplies
Posted by Razim armani on
Norman J Weimar Jr
  • Minolta Master
  • 6,960 Answers
Replace the drum and developer check the scanner section and check transfer section
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Feb 10, 2018
5 Related Answers
goalie39
Ed
  • 479 Answers
SOURCE: Clearing a service code ''C0400'' on a Minolta CS Pro 6001
C400 is exposure lamp fails to come on, on start up the main exposure lamp should come on and do a scan.
If the lamp is not detected by the sensor, then you get the code.
Restart the machine, watch for the exposure lamp. if it does not come on before the code occurs, then the lamp or thermal fuse is likely gone.
if the lamp comes on then the code, the AE sensor is likely gone.
Hope this is of some help.
Ed
Posted on May 11, 2009
Anonymous
SOURCE: Describe your minolta 6001 error code cof30
hopper motor is not moving, toner bottle not moving
Posted on Oct 01, 2010
noorzzz44
SOURCE: Minolta 6001 copier gives code
give me the map of main borad
Posted on Mar 08, 2011
safeer_cl
Safeer Ullah
SOURCE: Detaile of Code of Minolta
pleas send me cs pro 6001 code 611 salvation
Posted on Dec 02, 2012
firecontrol7
Norman J Weimar Jr
  • 6960 Answers
SOURCE: From meter counter how can I remove code m2 of minolta 6001
stop 0 stop 1 , counter, clear the drum and developer. ARE YOU REPLACING THE DRUM AND DEVELOPER,
The copier works on the counter clear the counter and not replace the parts that counter is monitoring and you will have codes and image problems the counters tell the copier parts are new and to adj assigned voltages as required.
Posted on Nov 21, 2015
I have an error code of c 6001 of konica minolta 368
you found the right place right time buddy.. i know a lot of websites for repairs and manuals that can really help u..
Minolta copier 6001 code C004A
Cooling fan for the Orginal glass. Check the fan for the big glass under the document feeder. Might be bad
What is ram pack and where is this in minolta copier 6001
The EP 6001 is not a digital machine. It is analog. As for RAM there is a memory for the counters on the screen but some one can clear it lucky there is the hard counter. What is the issue with this machine?
I have minolta copier 6001 and giving code m2 how I will remove
clear the counrters replace the drum and developer run the required F8
Minolta ep 6001 cf 0072
Sir/Mam,
open the front door and close it , wait a sec
Power off the machine
Take the toner bottle out!
power on the machine NO TONER BOTTLE IN IT
when the machine ask for toner put it in properly if the nub on the bottle is damage replace it that is how the bottle is turned bye the machine so ensure it is not damaged and install the correct bottle and correct TONER. The code is a problem with toner motor system.
11helpful
4answers
Detaile of Code of Minolta Ep 6001 coper
Feb 12, 2011 • Garden
2helpful
4answers
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Mehandi Husain ...
George Mclaughlin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
