For a full list of parts available contact 877-346-4812
replacementparts.com
the carby is available from e-bay as it fits srm-2000,2200 and gt 2000 series trimmers cost around $19.00
company is aitook parts store
seller information aitook2020 on e bay
google --e bay-- search carburetor for srm2000 srm2200 gt22000trimmes and it is the first seller
SOURCE: what is the walbro chain saw carburetor adjustment for a
There is no set adjustment on any chain saw. If it were that simple there
would be no need for adjustments. The problem is that most equipment
manufactured in the past 10 years can not be adjusted by the user. Carburetors
are now equipped with either adjustment limiters which limit the adjustment to
less than half a turn or with adjustment screws that require a special tool to
make the adjustment. More than likely you will have to take it to an authorized
dealer for those adjustments.
If you do have an adjustable carburetor,
then gently close both needles and open each on 1 full turn. This should allow
the engine to start and the final adjustments can be made at that point. If it
still will not start then open each needle 1/8 to 1/4 turn and try again. If
this still does not work then most likely your carburetor needs a good cleaning
and a rebuild kit.
SOURCE: Walbro Carburetor on Briggs & Stratton Model 28R707
If the float don't float, the needle valve stays open and gas runs into crankcase.
If float floats (has no gas inside) then the needlel is probably worn and needs replacement.
SOURCE: How to adjust the fuel flow in a Walbro carburetor
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Make surethe small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
