Question about HP Office Equipment & Supplies
ERROR CODE OXC18AOOOA THIS IS ON A HP OFFICEJET X451DN IT MAKE A NOISE LIKE GEARS NOT MATCHING UP I THINK IT WANT LOWERS THE INK
Posted by Derril Figgins on
Makenzie Floyd
    New Friend:
  • 11 Answers
I think it needs ink possibly?Check if you want to or need to.
Posted on Sep 19, 2017
5 Related Answers
Anonymous
  • 20 Answers
SOURCE: HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions,  try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to  hp at 1888 473 2963
Posted on Jan 26, 2009
Anonymous
SOURCE: error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
Posted on Mar 05, 2009
Anonymous
SOURCE: 0xc05d1281 HP-C7280 Ink System Failed -- tried
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Posted on Oct 20, 2009
deschilz
  • 44 Answers
SOURCE: Cartridge Error - HP Officejet 5610 - All-in-One
Hi daniel70,
I see that you have put in a new cartridge. Probably worth a shot to get some high quality rubbing alcohol and Q-tips then clean the contact (copper) points in the cartridge slot and on the cartridge.
To do this:
1. Power up the printer
2. Open the cartridge access door on the front right of the printer
The printer will move the cartridge holder assembly to the open-door section where you can get at it.
3, Then, unplug your printer. This protects the unit as you clean the internal contacts.
4. remove the black cartridge and look inside the printer at the cartridge holder slot with a strong flashlight. You will see contact points inside. Clean these with a small amount of rubbing alcohol on a Q-tip and blow the contacts dry.
5. You should also clean the back of the cartridge and make sure that the protective cover (supplied with the new cartridge) has been completely removed. Also, make sure it is dry before you put it back in the printer. Make sure it "snaps" in place as well.
Just a note that you can refill these cartridges many times with no issue and there is no restriction in this printer that prevents you from doing so (my black cartridge has been filled eight times). You can see my tip on this at:
http://www.fixya.com/support/r2641367-refilling_5610_cartridges_saves_big
Posted on Nov 07, 2009
Anonymous
  • 103 Answers
SOURCE: hp 4280 gear noise - loud clattering sound for a
Hardware failure,Go for a new unit.
Posted on Jul 26, 2010
Model 4225 shows error code only
'Ink System Failure,' or a '0x...' - HP Customer Support
support.hp.com/us-en/document/c03081973
Example: "Laserjet P1102w driver" or "HP Pavilion 17-f002na will not turn on" ... For example, 'Error 0xc18a0001' or 'B8000094' might display on the printer ... The error code or message is not 'Problem with Printhead,' 'Printer Failure,' or 'Ink ...
[PDF]hp officejet 4200 series all-in-one user guide
www.hp.com/ctg/Manual/c00095626.pdf
Hewlett?Packarduse the attached handset (hp officejet 4250 series only) . . . . . . . . . . . .50 answer incoming calls ..... Help button that appears on some error messages and in the. Troubleshooting .... a call waiting (handset model only). 9. Photo Fit to Page: ...
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Dec 18, 2015 | HP Office Equipment & Supplies
Error code 0xc6fd0413, unable to print or use the console.
There was a recall of a series of this printer with printhead cable problems. Call HP with your serial number and if it falls in the range they will send you a replacement printer.
Mar 21, 2015 | HP Officejet Pro X451dn InkJet Workgroup...
How do i find ink levels in Windows 8 for HP Office Jet J4580
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
ATASCO HP OFFICEJET J4585
When you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels cannot be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
Additionally, severe cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
Feb 22, 2013 | HP OfficeJet J4580 All-In-One Laser...
The exclamation mark is on and the screen is flickering hp j4580 officejet all in one
A flashing exclamation mark is typically associated with a sever cartridge error (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. Have you tried replacing the ink cartridge with a new HP genuine cartridge to confirm?
NOTE: The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
Jan 10, 2013 | HP OfficeJet J4580 All-In-One Laser...
Hp officejet j6480 cartridge error problems
This type of fatal cartridge error (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicates the internal micro-electronics of the HP #74/75 cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. However, our test group has also seen these failures with brand new cartridges. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on most models which use HP 74/75 cartridges. Refer to Inkjet411 youtube videos below on how to access respective printer's service menu and correct:
HP 74, 75, 74XL, 75XL Cartridges - Solving Errors & Warnings:http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart C4200-C4500 and C5200-C5500a Printers - Diagnostic Tap 41 Test: (verifies electrical health of ink cartridges):http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
Jan 12, 2012 | HP Officejet 5610 All-In-One InkJet...
"incompatible ink cartridge"
Printer needs to be reset:
1. Power OFF printer
2. UN-plug power cord at wall/surge protector
3. Turn ON printer (w/o power cord plugged in)
4. Plug in power cord
5. Turn ON printer
(This will reset the printer)
Sep 01, 2009 | HP OfficeJet J4580 All-In-One Laser...
Cartridge Error: Cart. on left is not intended for this printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab64
Jun 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Incompatible cartridge error in j 4580
refix your cartidge .may be your cartridge is faulty.
Dec 25, 2008 | HP OfficeJet J4580 All-In-One Laser...
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
