Question about Watches
Pendulum won't swing with batteries in - Watches
Posted by Lyle Lingenfelter on
Tom Weglarz
    New Friend:
    Problem Solver:
  • 12 Answers
It has to be started by hand..or move clock in a right to left sliding motion.. if this fails the swing mechanism is dead
Posted on Sep 21, 2017
5 Related Answers
David Tolond
  • 2501 Answers
SOURCE: Bergen Enkheim Clock won't stop chiming. The
It sounds as though part of the mechanism that controls the chiming is jammed. This could be caused by dirt or wear.
I suggest you have the clock cleaned as a first step and ask if there is any sign of damage.
Posted on Jan 06, 2010
Testimonial: "Thank you very much for the advice *. ~"
Anonymous
  • 714 Answers
SOURCE: The pendulum stopped swinging...the clock and
Hi
This clock short of needing a full service may simply be out of beat.
Taken from my web page located at:
http://antiqueclock.clockstop.com/CLOCK_BEAT.htm
"HOW TO PUT YOUR CLOCK IN BEAT"
-Included below is a 10-second sound <snip> of a clock both in and out of beat.
IN BEAT ////////\\\\ OUT OF BEAT
· Turn on your sound and click on the clocks above for a sound clip.
-One little known fact is that a clock does not have to be level to be in beat. I had a customer that had a mantel clock in an old farm house, it was brought in for repairs and sent back running great just one problem: I put the clock in beat on a level surface [a small problem] because the mantel it had set on for it's entire life was not level. I had to literally go to the house to put it in beat where it sat.
-I have often found most Grandfather or floor clocks are set up out of level and put in beat where they stand, This is fine.
-As I'm sure we now realize a clock must be in beat but not always level to function properly.
· Above is the verge with a slip clutch.
· Often found on Grandfather clocks and requires only a long swing to get it in beat.
-To get the clock on the right side in beat you would need to push the verge assembly to the left.
-If it must be bent to put it in beat, do it slightly, but don't bend any of the suspension parts.
R/ David
Posted on Jan 21, 2010
Anonymous
  • 714 Answers
SOURCE: the clock time cannot be set on a
You question is a bit non descriptive except that the clock does not work and the hand clutch has failed.
GOTO:
http://www.nawcc.org/business-directory/
Hopefully this will guide you in the correct direction for a local repair person.
Hope this tip helps
R/
David
Posted on Feb 15, 2010
Anonymous
  • 22 Answers
SOURCE: the pendulum won't continue to
This could be for too many reasons. It will not be possible to fix this without taking it to a qualified watch repairer who will be able to take a look and determine the exact fault.
It could be a blockage in the train of wheels.
It could be a broken balance staff or mal-adjusted balance spring.
May be broken palets or mainspring - the list goes on and on.
Find a local trustworthy watch repairer and they will give you a free estimate in most cases.
Best of luck.
Posted on Sep 21, 2010
small6363
  • 18429 Answers
SOURCE: pendulum will not stay swinging on mantle clock
check out the link below
http://www.youtube.com/watch?v=ps6dPxoxe9c
Posted on Jul 26, 2012
How to fix the pendulum on an elgin quartz anniversary clock
I am unsure wha you mean by "fix the pendulum". If you mean it stopped swinging, there are two reasons: first check the battery and contacts. Remember, even a new battery can be bad, which is why new things come with warranties. The other thing is quartz movements usually don't last too long. If the pendulum is not swinging, and is correctly attached to the movement and the battery is good, then the movement has gone bad and you need a new one. Most all clock shops keep quartz movements on hand. If you are a do-it-yourself type, you can get them off the Internet. Be sure to remove the old one first and check how thick the dial is, that's how they sell them by dial thickness.
Oct 26, 2017 | Elgin Watches
The pendulum on my grandfather clock no longer works .. It is not a problem with batteries . It just no longer moves .
wind the spring up
if is battery operated replace the battery that swings the pendulum
Aug 30, 2017 | The Watches
I have an Elgin Westminister Quartz Chime clock. Everything works fine, except the pendulum does not swing, anymore. Can I fix this or can I buy parts to fix this problem?
I have a clock with a pendulum and it has two batteries, one for the clock and one for the pendulum.
Perhaps your is the same?
Mar 13, 2011 | Watches
Re: Galleria / Metro Grandfather Clocck. W/ pendulum on lower hanger clock runs slow. W/ pendulum on upper hanger clock runs fast. How can I adjust so it will keep correct time, or should I take it to a...
Most grandfather/grandmother clocks have an adjustable screw on the weight to slightly extend it or shorten it to satisfy the equation of pendulum swing. the shorter the swing (arc distance) the faster the clock, the longer the swing the longer the time. Check to see if you can adjust the weight up or down on the hanger.
Jan 01, 2011 | Watches
I do not know how to start the clock : Clock under glass. Has three balls supposed to swing. I replaced the battery.
Lift the glass and swing the pendulum/balls. Or you could, if it's small enough to hold in your hand, suddenly twist it, there by using inertia to swing the pendulum.
Aug 03, 2010 | Watches
Bakelite antique mantle clock just bought, but no instructions of how to get it going. Ive got the key and pendulum but dont know how to set it up. Can you help?
First you have to wind up your clock using the key supplied. The pendulum suspension spring should start to swing quite fast. Stop it swinging with your fingers and hook up the pendulum. When done, push the pendulum to whatever side and release it to start the swing - the clock should start ticking in normal order. If there is no special bar on the back of clock movement for adjusting hands, then hands must be adjusted from the dial side by moving minute hand clockwise. Move the minute hand with your finger clockwise to the desired time, at the same time do not catch hour hand, as this may end up with the incorrect time displayed. Rate me, plz.
Jan 28, 2010 | Watches
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Watches Logo
1,694 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
