Question about Precor 9.35 Treadmill
How to reset password for precor treadmill 9.35?
Posted by Elenora Burckel on
Stephen Miller
  • Precor Master
  • 1,645 Answers
4 Related Answers
Anonymous
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: Precor 9.25i Treamill scrolls message "button is pressed"
Press Enter,speed up and speed down simultaneously. Then enter to view error buffer . press quick start/pacer-stop simultaneously to reset error buffer log. Hope this helps
Posted on Apr 11, 2010
Joshua
  • 95 Answers
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Posted on Jan 13, 2012
seanmccann_1
seanmccann_1
SOURCE: SPEED ERROR ON PRECOR 927 TREADMILL
I had the speed error on my precor 9.23. When I opened it up I found that there are two little round magnets on the belt pulley with a sensor mounted nearby. This must be how the computer know the speed of the treadmill. I noticed that there were several little metal shavings stuck to the magnets. Not sure where they came from, hopefully not another problem. However, I removed the metal shavings from the magnets and everything worked fine again. If anyone else has the speed error it might be worth a look to see if its the same problem.
Posted on Sep 07, 2012
How to change password on precore 9.35 treadmill?
Hello!
According to the manual (included in the link), there is no way to change the password on the Precore 9.35 Treadmill from its default setting.
If you would like to disable the password, follow these steps:
1. At the Precor banner screen, press STOP, SPEED?, SPEED?, ENTER, PROGRAMS very quickly
2. At the SELECT UNITS screen, press ENTER
3. Using the arrow keys, select DISABLED at the PASSWORD prompt
4. Press ENTER to accept these settings
https://www.precor.com/sites/precor.com/files/manuals/48854-103%2520933i_9.35i%2520Lit%2520Kit_1005_EN.pdf
Sep 18, 2017 | Exercise & Fitness
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Corrective Action
Removing a user I'd password from a precor 935 2005
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Dec 21, 2013 | Precor 935 Premium Series Treadmill
Treadmill precor 932 er05 error
Corrective Action
Mar 31, 2013 | Precor 935 Premium Series Treadmill
How to unlock safety code for precor 9.35 treadmill
• Set User Name
Procedure
Sep 27, 2012 | Precor 9.35 Premium Series Treadmill
Password reset
• Set User Name
Procedure
Aug 24, 2012 | Precor 9.31 Treadmill
What is the password the get the precor 3.1 treadmill to work?
• Set User Name
Procedure
Jan 27, 2012 | Precor 9.31 Treadmill
We forgot the password on our treadmill. How can we reset the password?
• Set User Name
Procedure
Mar 08, 2011 | Precor 935 Premium Series Treadmill
Apr 06, 2010 | Precor 9.21 Treadmill
Precor 9.35 Treadmill Logo
573 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
