Vacuums Logo
Question about Kirby Vacuums
Used the Kirby shampooer. It seemed to work well. Foamed ok and picked up foam ok. Capet looked clean. Next morning white streaks were noted on the carpet. What should I do to fix it?
Thatvacguy.com
  • Kirby Master
  • 1,619 Answers
White streaks might be soap residue, get carpet slightly wet and agitate it to see if it foams up. It may dpneed to be rinsed out.
Posted on Sep 19, 2017
5 Related Answers
Anonymous
SOURCE: Kirby Ultimate G carpet shampooer not producing foam anymore
I was having the same problem. There is a filter plug that came loose on mine and went down into the hose. It belong on the water tank and fits in there tightly and the hose end goes over it. That's what actually makes the foam.
Posted on Aug 25, 2007
Anonymous
SOURCE: Kirby G4 not distributing shampoo...
Thanks kathy, that's exactly what my problem was, the screen was stuck in the hose.
Susan
Posted on Oct 20, 2007
RockyNR1
Rocky
  • 324 Answers
SOURCE: have kirby g4 carpet shampooer, need instructions for shampooer
Check out the online shampoo manual HERE
Good Luck,
Rocky
Posted on Mar 28, 2009
Anonymous
  • 3 Answers
SOURCE: where does the carpet fluffer to on the kirby shampooer
you remove the 'vacuum' head and use the same one as for the shampooer (on mine at least)
Posted on May 18, 2009
Anonymous
  • 274 Answers
SOURCE: why wont my kirby carpet cleaner pick the foam and
Is the carpet washer attached to unit is the belt hooked up? don't use the vacum head you well get shocked.be careful
Posted on Jul 26, 2010
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
tip
How To Attach The Carpet Shampooer To A Kirby Generation 5 (G5) Vacuum Cleaner
The Kirby carpet shampooer is an attachment that is used with the Kirby upright vacuum cleaners. It converts the Kirby from being used as a dry pickup vacuum, into a carpet shampooer and extractor. Unlike other carpet shampooers and carpet extractors, the Kirby shampoo system does not saturate the carpet with a lot of water when cleaning. Kirby shampoo systems use a special dry foam formula that gently cleans the carpet without saturation.
Installation
The link below is to an excellent, easy to follow and understand video that will explain step by step how to convert the Kirby Generation 5 (G5) from a vacuum cleaner into a carpet shampooer. Please note that the vacuum in the video is actually a newer Sentria model, however the repair procedure is identical on the G5 as it is on the Sentria.
Video Demonstration of Converting Kirby Generation 5 From Vacuum Into Carpet Shampooer:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If you have any questions about the procedure of converting the Kirby G5 into a carpet cleaner, please feel free to request clarfication on this video right here on the Tip page. I hope that this video was helpful. If you did find the video helpful, please kindly rate this Tip as helpful by clicking on the Thumbs Up Icon in the lower right hand corner of the page.
Thank you very much for watching,
Chris J.
3helpful
My kirby shampooer doesnt seem to be placing foam on the floor like it should and it's not picking up any at all
Mine did that once and we were missing the filter part on the end of the shampoo hose attachment.fits on the end of the hose. Bought a new one at the Kirby store for cheap. It looks like a filter screen and without it just seems to soak the carpet without foaming up or cleaning it very well.
1helpful
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
Sudser not working right
You may be missing the little foam cap that goes on the tank end of the hose from tray.It's about the size of a quarter,and gray in color.Should be able to pick that up from any vacuum shop,or directly from Kirby.Jus ask for the shampooer foam screen.
2answers
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
2answers
Kirby carpet cleaning problems
http://www.greatvacs.com/kirby%20instructions.shtml
Note: This is just a website i found with the instructions. Don't hold FixYa, or me liable. But it did look pretty spot on when I did a quick browse through.
Hope this helps.
1helpful
Kirby shampooer
On the shampooer tank, remove the screen cap from the little hole that the shampooer hose plugs onto. Clean the screen and make sure that it is not plugged up with debris. Make sure that the screen is securely glued to the cap all the way around the edge. (they sometimes come loose and this will cause the absence of foam) That little (approx. 1 inch diameter) screen is the main ingredient for the foam. The screened cap should fit firmly onto the outside of the little hole in the bottom of the edge of the tank.
If none of this helps, remove the round sponge and look at the holes in the white plastic circle. Turn the on/off foam valve and make sure that the holes open up when the valve is turned to "on". You can purchase and replace the on/off valve if it turns out to be the problem. You can also buy a replacement tank if you're not inclined to mess with it.
If you need another shampooer manual, check out my guide....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps...
Marci
Top Kirby Vacuums Experts
David Shaub
Paul Bade
W.L.
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
