Question about Panasonic Cameras
My Panasonic HDR-H101 hangs up. Only Zoom Button works, Others does not mov
Posted by Nurul Islam molla on
1 Related Answer
emissionwiz
Marvin
  • 85239 Answers
SOURCE: After switched on my Panasonic SDR-H101 hangs up No button works accept Zoom one. How to make all buttons active so that option can be changed from one to another.
It is faulty have it repaired or replace the camera.
Posted on Sep 18, 2017
Tip
Import MTS to Final Cut Pro X-Convert Sony PJ30V 60p MTS to H.264 MOV for...
The Sony PJ30V has more compression options than your average camcorder. Most of its video is recorded using AVCHD compression, which is today's industry standard. The HDR-PJ30V has 32GB of internal flash memory and it can record Full HD video using 60p, 60i, or 24p frame rates. The PJ30V comes with the same version of Picture Motion Browser (PMB) software that shipped with the Sony HDR-CX700V, which we reviewed earlier this year. The new version of the software is nearly identical to previous versions of PMB, except version 5.5 does allow you to import and work with 60p and 24p clips (something that is essential for the HDR-PJ30V). One big downside, we noticed in terms of editing, is that the 60p clips recorded by the PJ30V don't always play nice with mac editing software. Final Cut Pro version 5.0, for example. And Now <b>Final Cut Pro X</b> is available could be Downloaded from the Mac App Store. However <b>Log and Transfer was removed</b> in the X version of Final Cut. So all Pro mts camcorder owners who use Final Cut are looking for <b>HD Camcorder MTS Converter Software</b>. <br /><br />Here is the step-by-step guide to quickly use Final Mate for Mac to <b><a href="http://sony-mts-converter.com/2011/06/import-mts-to-final-cut-pro-x-convert-sony-pj30v-60p-mts-to-h-264-mov-for-editing-in-fcp-x/">Import/Convert Sony PJ30V 1080/60p MTS to H.264 MOV for editing in FCP X</a></b> on Mac. <br /><br />Step 1. <b>Capture native MTS from Sony PJ30V to Aunsoft Final Mate for Mac</b>. <br />Run Aunsoft Final Mate for Mac as the fast <b><a href="http://www.aunsoft.com/final-mate-mac/">Import AVCHD MTS to Final Cut Pro X</a></b> on Mac, and drag the .mts files already backup all mts recordings from Sony PJ30V to your computer, and can browse the .mts video path and the software will automatically show your AVCHD clips in "Resource Tab". <br /><br />Step 2. <b>Create a Movie for combine and convert Sony PJ30V AVCHD MTS 1080p footage</b>. <br />Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created. <br /> <br />Step3. <b>Convert MTS files to H.264 MOV for Final Cut Pro X</b>. <br />Click the Export button. Follow HD Video &gt; H.264 HD Video (*.mov) to choose output format for editing in Final Cut Pro X. You can then adjust video parameters to keep original video resolution, bitrate, framerate, etc with highest quality. The <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac MTS to Final Cut Pro X Conversion</a></b> will start <b><a href="http://www.aunsoft.com/final-mate-mac/">converting MTS to H.264 MOV</a></b>. <br /> <br />After the conversion, the AVCHD videos could be imported to Final Cut Pro X with 60fps highest quality. Of course, you also can choose <b>Final Cut Pro &gt; Apple ProRes 422 (*.mov)</b> as output format for without rendering. ProRes is advertised codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. <br /><br /><b>Tips:</b> The Final Mate For Mac support camcorder includes but not limited to Panasonic HDC-TM900,TM90,SD90,HDC-TM700/HS700/SD700, SD60/HS60, DMC-GH2,GH1,GF2,ZS7/TZ10; Sony HDR-CX700, CX550, XR550, XR520, CX350, CX305, CX150,CX360, Alpha NEX-5,DSC-HX5V; Canon Vixia HF200, HF S100,HG10,HG20,HF R10,HF R11,HF R100.etc If you want to know more about Camcorder, please visit the <b><a href="http://www.aunsoft.com/camera/sony.html">Camcorder column</a></b> for more information.
on Jun 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Convert and Edit Sony HDR-FX7/XR150/CX110 Series to Mac, iMovie, FCP
Sony HDR series Camcorders are High Definition Models, which store video in AVCHD MTS/MPEG-2. As a kind of popular HD camcorder, Sony HDR series own several hot family members including Sony HDR-XR150, HDR-XR500V, HDR-CX110, HDR-CX150, HDR-FX7, etc. Sony HDR series Handycam is lightweight, recording in high definition with good video quality, easy to use.
If you decide to select one, now, the following list of Sony HDR Series Camcorders you can check:
Sony HDR-CX Series: HDR-CX100, HDR-CX110, HDR-CX120, HDR-CX150, HDR-CX300, HDR-CX500V, HDR-CX550V, etc.
Sony HDR-SR Series: HDR-SR12, HDR-SR11, HDR-SR7, HDR-SR100, HDR-SR200, HDR-SR10E, HDR-SR12E, etc.
Sony HDR-XR Series: HDR-XR100, HDR-XR150, HDR-XR200, HDR-XR350V, HDR-XR550V, HDR-XR200E, etc.
Other Sony HDR Series: HDR-HC7, HDR-HC9E, HDR-FX7, HDR-FX7E, HDR-UX10, HDR-UX20, HDR-AX2000, HDR-TG5, HDR-TG5E, etc.
(Some of Sony HDR Camcorder Compatible with iMovie' 09) http://support.apple.com/kb/ht3290
Owing to Sony HDR Handycam recording video in AVCHD MTS/MPEG, or miniDV, for Mac users, you cannot directly import these MTS, MPEG, miniDV video to Mac to edit with iMovie, FCP, etc.
If you want to convert and import Sony HDR video to Mac, how to do that?
Sony HDR Video Converter for Mac is the best solution to tansfer Sony HDR video like AVCHD MTS, MPEG2, miniDV, etc to MOV, MP4, M4V, 3GP, H.264 for Mac. With this AVCHD Converter for Mac, you can easily convert camcorder video such as MTS, M2TS, TOD, MOD, MPEG, etc to MOV, MP4, AVI, 3GP, FLV, MPEG-4, MP3, etc for Mac, iMovie, Quicktime, iDVD, FCP, FCE, Adobe Premiere Pro, iPad, iPod, iPhone, Blackberry, Youtube, etc.
Quick Guide to Convert Sony HDR Video to Mac, iMovie, Quicktime Step by Step
Step One: Import Sony HDR Video
Click "Add File" to add your Sony HDR AVCHD MTS or MPEG-2 files to Mac AVCHD Converter after you launched it. You can upload several videos one time.
Step Two: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step Three: Convert Sony HDR Video
Click "Start" button to convert Sony HDR video like AVCHD MTS/M2TS, MPEG-2, miniDV files to Mac. After conversion finished, you can enjoy converted Sony HDR video on Mac or edit these videos with iMovie, FCP, Adobe Premiere Pro, etc.
More Tips: How to convert and import Sony DCR Series video to Mac, iMovie?
How to convert/import Panasonic HDC series to Mac and edit Panasonic HDC Video in iMovie, FCP?
on Oct 28, 2010 | Computers & Internet
Tip
Convert/Import MTS, M2TS files to FCP MOV, MP4, DV on Mac OS
MTS format is high-definition MPEG, AVC, H.264 transport stream video file format which commonly used by HD camcorders such as Sony, Canon, Panasonic, JVC. HD camcorder makes use of MTS in the form of AVCHD, a format for recording and playback of high definition video.
Nowadays, most digital camcorders record videos in AVCHD MTS/M2TS format that is a high-definition and high quality video format.
Here you can check the list of some popular HD camcorders recording video in AVCHD MTS/M2TS format including Canon, Sony, Panasonic and JVC as follows:
Canon HF10, HF100, VIXIA HF S100, VIXIA HG21, VIXIA HF200, VIXIA HF S200, VIXIA HF M300, HG20, HG21, IVIS HF M31, IVIS HF R10
Sony HDR-SR1, HDR-SR10, HDR-XR100, SDR-SR10, HDR-SR11, HDR-XR100, HDR XR-500V, HDR-TG1, HDR-CX7, HDR-SR5, HDR-CX7
Panasonic HDC-SD60, HDC-SD100, HDC-SD200, HDC-HS100, HDC-HS350, HDC-HS700, HDC-TM35, HDC-TM350, HDC-TM700, HDR XR-500V
JVC GZ-HD10KR, GZ-HD30, GZ-HD40, GZ-HM200, Everio HD10, Everio GZ-MG130
HD camcorder owners can enjoy HD video with their HD camcorder, however, original AVCHD MTS, M2TS files cannot be directly imported to Mac. So for Mac users, if you want to import MTS/M2TS video to FCP(a highly-regarded video editing, compositing, and special effects package for the Macintosh) on Mac for editing, you have to convert MTS/M2TS files to MOV, MPEG-4, DV for FCP firstly.
Doremisoft MTS to FCP Converter for Mac is the best software to convert original MTS, M2TS files to Final Cut Pro with good quality. It can transfer MTS video to MOV, MP4, M4V, AVI, DV, 3GP, etc and other HD videos like HD MP4, HD MOV, etc. With this AVCHD Converter for Mac, you can convert MTS video to FCP, FCE, iMovie, Quicktime, iTunes, iDVD, iPad, iPod, iPhone, Blackberry, PSP and so on.
Easy Tutorial for you to convert MTS/M2TS files to FCP on Mac here:
Step1: Import MTS, M2TS Files to Mac MTS Converter
Click the "Add File" to upload your chosen AVCHD MTS, M2TS files to MTS to FCP Converter for Mac after you lauched it.
Step2: Set Output Video Format for FCP
Click "Profile" to open the Profile drop-up list to select MOV, MPEG-4, or DV as output video format for FCP on Mac OS. And you also can convert MTS files to iMovie, Quicktime, iDVD, iPod, iPhone, PS3, Blackberry, etc.
Step3: Convert MTS Files to FCP
Click "Start" to convert AVCHD MTS, M2TS videos to FCP on Mac. you can edit your converted MTS, M2TS files with FCP on Mac OS X after converting finished.
Related: How to Convert MTS, M2TS to iMovie for Editing?
How to Convert Panasonic HDC Series to Mac and Edit Panasonic HDC Video in iMovie, FCP?
on Oct 21, 2010 | Computers & Internet
Tip
Best HD Camcorder for Mac, iMovie, iMovie? 08, iMovie? 09
Recording daily life and interesting things with a HD camcorder becomes a trend for our people. They like to share these digital camcorder videos on Mac or PC with family and friends. However, selecting a good digital camcorder for Mac is not easy for green hand. Maybe more tips need paying attention, for example, the types of your camcorder and Mac, the version of iMovie on Mac, Mac and PC compability with digital camcorder and so on.
iMovie has been a Mac OS X only application bundled in the iLife suite of Macintosh applications since iMovie3. From 2007 to 2010, Apple developed iMovie to iMovie' 08, iMovie' 09, and iMovie for iPhone and iPod Touch. Luckily, iMovie' 08, iMovie' 09 are designed to work with a wide range of digital video devices and formats, including tape-based(use a FireWire cable, also known as IEEE 1394 or i.Link) and the latest tapeless camcorders that record to flash memory, a hard disk drive(HDD), or DVD media.
A list of Digital Camcorders Compatible with iMovie' 08, iMovie' 09 on Mac OS X
NTSC Camcorders(a video format used in North America, Central America, Japan, and parts of South America)
Canon: DC20, DC50, DC220, DC230, FS10, FS11, FS100, HF10, HF11, HF100, HG10, HG20, HG21, HR10.
JVC: GZ-HD10, GZ-HD30, GZ-HD40, GZ-MG330, GZ-MG67, GZ-MG255, GZ-MG555U, GZ-MG505U.
Panasonic: HDC-DX1, HDC-SD5, HDC-SD9, HDC-SD20, HDC-SD200, HDC-HS9, HDC-HS20, HDC-HS100, HDC-HS200, HDC-HS300, HDC-SX5, SDR-H50, SDR-H60, SDR-H200, SDR-S10
Sony: HDR-CX11, HDR-CX12, HDR-SR1, HDR-SR7, HDR-SR11, HDR-TG1, DCR-SR82, DCR-SR200, DCR-DVD308, DCR-DVD508, DCR-DVD403.
PAL Camcorders(a video format used in Europe, Africa, the Middle East, most of Asia, and parts of South America)
Canon: DC50E, DC220E, DC330E, FS10E, FS100E, HF11E, HF100E, HG10E, HG20E, HG21E.
JVC: GZ-HD10KR, GZ-HD30, GZ-HD40, GZ-MG255, GZ-MG67, GZ-MG155, GZ-MG330.
Panasonic: HDC-DX1, HDC-SD9, HDC-SD200, HDC-TM20, HDC-TM300, HDC-HS20, HDC-HS200, HDC-HS300, SDR-H79, SDR-H60, SDR-S15, SDR-S26.
Sony: DCR-DVD908E, HDR-CX11E, HDR-CX12, HDR-SR1E, DCR-SR5E, HDR-SR12E, HDR-TG1E, HDR-CX7E, HDR-UX20E, DCR-SR82E, DCR-SR100E, DCR-SR300E.
Although iMovie' 08, iMovie' 09 on Mac OS work with most of HD digital camcorders using MPEG-2 (standard definition), MPEG-4, AVCHD, and H.264 formats, not all tapeless camcorders are compatible with iMovie' 08, iMovie '09 because of the wide range of media types and the different ways manufacturers store video on these media types.
How to fix it? To meet people editing AVCHD, MOD files with iMovie, enjoying HD camcorder video on Mac, a powerful HD Video Converter for Mac is specially designed for people who need to convert AVCHD MTS/M2TS, MOD, TS, TOD, MKV files to iMovie MP4, MOV, DV for better editing. Besides, that Mac HD Converter is also the very choice to convert HD video like TP, TRP, M5S, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD to Mac application: iTunes, iDVD, FCP, FCE, etc.
Related: Click here to see more info of AVCHD Converter for Mac for people to convert AVCHD files to Mac iMovie, iPod, iPad, iPhones, PSP, BlackBerry, Zune and other handy device.
How to Convert AVCHD MTS/M2TS to Mac formats?
on Sep 21, 2010 | Computers & Internet
Tip
Sony HDR Video Converter Mac - How to convert Sony HDR AVCHD files to...
With one Sony HDR series camcorder, you can capture your daily life, recorded much good time. But you want to import some movies to editing softwares like iMovie, Final Cut Pro, Avid, Adobe Premiere, Final Cut Express etc on mac for further editing, sometimes you maybe in a trouble that sony HDR videos can't be imported to them directly.
To solve this problem, let us learn something first. Sony HDR series camcorders are High Definition Models. Most of sonny HDR camcorders create avchd or avchd/mpeg-2 videos. But the files extension may be different. The output format of HDR-SR12 is mpeg, the output of Sony HDR-SR10, Sony HDR-SR11, Sony HDR-XR100, Sony HDR XR-500V, Sony HDR-TG1, Sony HDR-CX7, SDR HDR-SR5 are .mts file. So the first step you should do is convert your sony videos to the other video formats which can be supported by editing software on Mac, such as .mov, .mp4 etc.
Mac Sony HDR Video Converter is a professional software which specially designed for solving this problem. Sony HDR Video Converter Mac can help you convert your original sony videos not only .mpeg but also .mts/m2ts videos to other pop video formats such as mp4, wmv, mpg, mkv, mov, etc. Finishing your flexible conversion just in several mouse clicks and there is no need to worry any quality loss.
With Sony HDR Video Converter for Mac versatile powerful function, you can edit your sony HDR videos more choices, like crop video area, set video brightness, contrast, and saturation effects, and customize video/audio output settings, trim sony HDR video length. Then you can put your videos on portable devices for playing, like PSP, iPod, iPad, iPhone, iPhone 4 etc. Creating yourself personalized videos and enjoy them by using Sony HDR Video Converter for Mac.
http://www.ilifesoft.com/how-to/convert-sony-hdr-video-on-mac.htm
on Aug 03, 2010 | Cameras
Tip
Upload Sony NEX-5 MTS to QuickTime H.264 MOV for YouTube Sony Alpha NEX-5 is one...
Sony Alpha NEX-5 is one of the interchangeable lens digital cameras, with all the components, bodies and lenses support the feature to tackle continuous autofocus and exposure adjustment while recording video. The Sony NEX-5 supports recoding 1920x1080 AVCHD video.
With the HD videos filmed by Sony NEX-5, you may want to upload them to your YouTube account for sharing with friends and families. However, YouTube does no support .mts files yet. One of the fast solutions is to convert .mts videos to QuickTime H.264 MOV with Mac Sony NEX-5 MTS to MOV converter. Aunsoft MTS/M2TS Converter for Mac is the recommended tool for you to share Sony NEX-5 videos.
Have a look at the steps below to upload MTS HD videos to YouTube on Mac OS X like Snow Leopard.
Step 1. Load Sony NEX-5 videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony NEX-5 MTS to MOV converter, and click the "Add" button to load .mts videos for conversion.
Step 2. Choose QuickTime H.264 MOV format.
Click the "Format" option, and choose HD Video > H.264 HD MOV(*.mov), and the Mac Sony MTS to MOV converter will transcode the HD MTS files to MOV for YouTube. As YouTube supports HD video in 1920x1080 and 1280x720, the default settings in the profile are OK for uploading.
Step 3. Convert Sony NEX-5 MTS to H.264 MOV for YouTube.
Click the convert button under the preview window, and the Mac Sony MTS to MOV converter starts converting 1080i MTS to HD MOV for uploading to YouTube.
After the conversion is finished, log in your YouTube account and browse the output QuickTime H.246 MOV for uploading to YouTube. The Mac Sony NEX-5 MTS to MOV converter also deinterlaces AVCHD videos. It is easy to share camera video on YouTube without interlacing problem for watching on computer. The converter also works with Sony HDR-XR500, HDR-CX110, Cyber-shot DSC-TX7 and other AVCHD cameras.
The NEX-5A with the 16mm lens sells for US$650, while the NEX-5K with the 18-55mm lens will sell for US$700.
on Jul 28, 2010 | Cell Phones
Tip
Mac Sony HDR-SR11 MTS to Avid converter-Convert AVHCD to Avid I have Sony...
I have Sony HDR-SR11 AVCHD HDD camera to shoot family videos and beach videos. However, after I transfer .mts files from Sony HDR-SR11, Avid does not support the AVCHD file. I wonder the best AVCHD workflow into Avid from Sony HDR-SR11 and google for solutions.
I was recommended with Sorenson Squeeze to convert Sony HDR-SR11 MTS to Avid DNxHD codec. However, Sorenson Squeeze does not natively support .mts and the file extension should be changed to .m2ts. The conversion time is much longer than that the original clip. One thing should be mentioned is that the exported DNxHD is loaded quickly to Avid. Sorenson Squeeze also costs quite a lot. I just find a better Mac Sony HDR-SR11 MTS to Avid converter - Aunsoft MTS/M2TS Converter for Mac. The price is dramatically low comparing to Sorenson Squeeze, and the output MOV video works in Avid MC and Xpress Pro.
Here is how I import Sony HDR-SR11 camera videos to Avid Media Composer by converting 1920x1080 MTS to HD MOV.
Step 1. Load Sony HDR-SR11 videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR11 MTS to Avid converter on Mac Snow Leopard, and click the "Add" button to load HD .mts videos.
Step 2. Choose AVC MOV for Avid.
Click the "Format" option, and choose Adobe Premiere/Sony Vegas > MOV (AVC)(*.mov), and the Sony MTS to Avid converter will transcode the HD MTS files to MOV for Avid MC, Xpress Pro.
Step 3. Convert Sony HDR-SR11 AVCHD to Avid.
Click the convert button under the preview window, and the Sony MTS to Avid Converter will start converting HDR-SR11 AVCHD MTS to HD MOV for Avid Xpress Pro, or the upgraded Media Composer 5.
As soon as the conversion in finished, you can import Sony HDR-SR11 videos to Avid Media Composer, Avid Xpress Pro for editing. The output HD MOV also works in Final Cut Pro and iMovie, and other non-linear editing software like Adobe Premiere on Mac OS X.
If you are using other Sony AVCHD cameras, you may also face the same problem. Have a look at the Sony HD camcorder page for Sony HDR-XR520, HDR-CX110, DSC-TX7, HDR-TG7 and other models.
on Jul 26, 2010 | Cameras
Tip
Transfer/Edit Sony HDR-TG3 1080i AVCHD Videos on Windows/Mac Sony Handycam...
Sony Handycam HDR-TG3E is a super small camera with full HD recording on Memory Stick in 2008. It includes 4GB and 10x optical zoom for capturing 1920x1080 and 1440x1080 videos. However, this camera does not include progressive recording mode, which indicates that the HD videos are 1080i. Even though it is compact camera, the audio is recorded in Dolby Digital 5.1ch. You can also take 2.3Mp stills while you are recording video footage.
Sony HDR-TG3E features:
- 1920x1080i HD video recording
- 4 megapixel still photo recording
- Dual Rec simultaneous 2.3 megapixel still photo during video recording
- Handy face detection
- Carl Zeiss Vario-Tessar lens
- ClearVid CMOS Sensor and Exmor derived technology
Videos from Sony HDR-TG3E:
Movie Format:
- High Definition: AVCHD (1920 x 1080, 1440 x 1080) in .mts filename extension
- Standard Definition: MPEG2 in .mpg filename extension
Movie Quality:
- HD: FH (1920x1080i, 16Mbps) / HQ (9Mbps) / SP (7Mbps) / LP (5Mbps)
- SD: HQ (9Mbps) / SP (6Mbps) / LP (3Mbps)
Transfer & Edit Sony HDR-TG3 AVCHD videos:
For Windows users:
Install the Picture Motion Browser (PMB) from the bundled CD in box, and connect Sony HDR TG3 to PC via USB cable. Use Sony PMB to download HD .mts videos from camcorder to PC.
For Mac users:
You can capture and transfer Sony HDR-TG3 1080i videos to iMac/MacBook Pro via iMovie after connecting camera to computer with USB cable. However, you may face problem when trying to log and transfer AVCHD videos from Sony Handycam HDR-TG3E to Final Cut Express (FCE) 4 or Final Cut Pro (FCP) 5. After transferring HD .mts videos from camera to computer hard drive, just run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-TG3 MTS converter to deinterlace .mts videos and convert .mts to .mov for FCE and FCP, if you want to edit HD videos.
Alternative way to transfer HDR TG3 videos for Mac and PC:
Just connect HDR TG3 pocket camera to computer via the USB cable, and the HDR TG3 will display as a hard drive on computer. Navigate to the HDR TG3 hard drive to access the memory stick.
Tips: Sony Handycam HDR-TG3E is the model for Europe, and Sony Handycam HDR-TG1 is the model for US.
on Jul 14, 2010 | Cell Phones
Cameras Logo
Top Panasonic Cameras Experts
ENFORCER
deton8 von Splosion
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
