Question about Stanley Camping, Backpacking & Hiking
Disassembly of Stanley MaxLife 369 flashlight
Posted by Theodore Hunter... on
oldhess
  • 50 Answers
Unscrew the caps on the bottom of the legs - each leg has 3 AA batteries
Posted on Oct 22, 2017
Stanley flashlight keeps blinking like a strobe light how can I fix it
I assume it is an LED flashlight (you did not say). Cheap Chinese-manufactured LEDs will flicker in this way when they go bad. The condition is not repairable... you will need to replace the flashlight. (Save the batteries.)
May 11, 2015 | Stanley Camping, Backpacking & Hiking
Replace batteries for stanley 95-112 flashlight
95-112B - Stanley Tripod Flashlight battery replacement is in the center chamber. Open the three legs, then put your fingers around the bottom part of the center chamber and turn counter-clock wise. Wella put in 3 new AA Batteries.
Apr 14, 2014 | Stanley 3in1 Tripod LED Flashlight 95155
What is the purpose of the screw at the base of the 95155 stanley 3 in 1 tripod flashlight
The pin has 2 magnets on it. When you hit the open button it pushes the pin down and releases the legs.
Aug 23, 2012 | Stanley 3in1 Tripod LED Flashlight 95155
I have a Stanley tripod flash light that taked 3 AA batteries in each leg of the tri pod. On one of the legs the batteries corroded inside and I can't seem to get them out . Any suggestions to this...
After drilling each leg to remove my corroded batteries I found that each leg isa push fit allowing it to seperate from the body thus allowing a screwdriver to be pushed thru releasing the corroded batteries. Re-assemble assuring a tight fit to make connection and it works well. Good luck I was drilling 1 leg for hours and the other 2 took ten minutes.
Aug 09, 2011 | Stanley Bostitch Maxlife Mini Tripod...
How do i install batteries on stanley 95-112 tripod flashlight
I just found it! The batteries go into the tripod legs! genius
Dec 30, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
I have maxlife 369 tripod. how do i put in new batteries
unscrew the caps on the bottom of the legs - each leg has 3 AA batteries
Dec 29, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Where do the batteries go in my stanley tripod flashlight?
Hello, The batteries are located inside each leg of the flashlight. Just remove the end cap on each leg by twisting it off. Inside each leg is 3 AA batteries.
Good Luck! Rich L.
Nov 28, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Camping, Backpacking & Hiking Logo
3,583 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Tom Chichester
Mr.Mike
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
