SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
SOURCE: Oven stop working
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
SOURCE: amana range model 770M door won't fully close
Is the door hitting the door lock hook. Or a strike pin hitting the inside door panel. If this is a self cleaning range the door seal is a metal mesh and does hold the door slightly away, this is normal. More info ?
SOURCE: The ignition feature seems to have stopped working
as both top and oven quit at the same time
if the lighting mechanism was a clicker type you used to her a snapping noise
for the top burners ovens are normally a hot surface ignition or glow rod the first thing i would make sure the outlet has power all four burners on top use same spark module and normally oven is separate module or control each burner control provides power to module separatly when turned on and you can test voltage at spark module mormally located behind a cover on back of stove
caution modules are wired 120volt and you would need a tester follow cord from outlet to where it enters back of stove normally wiring is close to cord entry point
SOURCE: Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
