Electrical Supplies Logo
D
David Larson Posted on Sep 16, 2017
We need a D.G. King Way P0800 plug - Electrical Supplies
2001 Harley Davidson Road King. No power to fuel pump, no check engine light, no spark to the plugs.
Question edited for clarity.
Question moved from 'Power Computers'.
It could be many things, fuses, battery voltage, sensors, ECM etc. Lots of video help and a link to the Harley Davidson Forums.
https://www.google.com/search?q=2001+Harley+Davidson+Road+King.+No+power+to+fuel+pump%2C+no+check+engine+light%2C+no+spark+to+the+plugs
2004 320D E46 NO ENGINE LIGHT AND RECEIVED CODES P0800 AND P0C00C
Could be the costly car is old and high mileage.
What code 2564
Codes above P0800 series are considered manufacturer specific. So each manufacturer can make up their own definitions. Without year, make, model, engine, no one can answer your question.
I ne to know what trouble code P144A means
Codes greater than P0800 are always MANUFACTERER specific code, which means we would need the year, make, model, and engine to decipher that for you.
Do you need to drain the kool king ac?
What kool king? Some are fully evaporative, some partial. None the less depending on humidity and how much condensation machine is producing all need drained. Typically it will shut down when and if it needs drained but if you are concerned, pull the plug!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
What does code PU401, PU463,P1189, and U1040 mean???
U, B, C and P codes above P0800 are considered enhanced manufacturer specific codes. So without knowing the year, make, model and engine, nobody can answer your question.
1helpful
2006 dodge 1500 hemi-trouble codes p0700 and p0800, what are they?
the P0700 means Transmission Control System (MIL Request)
the P0800 means Transfer Case Control Circuit
hid conversion kits
I just did a minor tune up on my acura 2000 tl i changed the transmission fluid oil and filter plus the spark plugs and now my car starts jerking when im driving or when i take off i conected the obd2 but...
You've got trouble codes stored by they're most likely enhanced codes that your code reader can't read. Inexpensive code readers and only read generic trouble codes. Codes above P0800 are "enhanced" code that require a more professional scan tool to access.
13helpful
2answers
Location of oil drain plug on harley davidson road king
The tank on your Road King is on the bottom of the transmission. Look underneath the transmission and you'll see two drain plugs. The plug on left front of the oil pan is the engine oil drain. The plug near the center of the pan is the transmission drain plug. Good Luck, Steve
Top Electrical Supplies Experts
john h
CJ Rock
CJ Rock
Are you an Electrical Supply Expert? Answer questions, earn points and help others
