Question about Microwave Ovens
No it is sensor microwave that says reset filter
Posted by Linda Harrington on
acmservice
    Sergeant:
  • Microwave Ovens Expert
  • 270 Answers
What brand and model??? Some of the companies just have a message post to remind you to clean the filter but have no actual sensors on it to see there is reduced air flow. It just comes up after a predetermined time intervval. They usually wil go off on their own after a short while. A day or two, maybe.
Posted on Oct 19, 2017
Where is adora microwave filters
Mary open microwave door and press the acess panel above the cavity opening where it says push, this will lower the panel door to the filter. just in case of any issues www.geappliances.com they will assit. Marcus
The reset filter light is not turning off even after I have changed the filter? How do you turn that off? I tried cancel and I tried to reset Microwave and nether is working.
MOST OF THOSE WARNINGS ARE JUST A TIME INTERVAL THING AND DO NOT INVOLVE ANY SENSORS THAT NEED TO BE REPLACED ONLY HAVE TO FIND THE PROGRAMING TO SHUT OFF THE WARNING IF YOU HAVE THE MANUAL FOR THAT UNIT FIND THE INSTRUCTIONS ON HOW TO SHUT OFF THE FEATURE THERE
The reset filter light came on for my LG microwave. What do I do?
Check your user manual. It should describe how to reset this light. These types of service filter indicators are activated after a set amount of time determined by the manufacturer has elapsed. The microwave has not actually detected a dirty filter, it's just a reminder that its time to clean the filter.
It is a GE microwave that says reset filter
Open the microwave door and press the access panel above the cavity opening where it says "PUSH" to lower the panel door. Models with an Upfront Filter have a Reset Filter notification light on the control panel to indicate when it is time to change the filter. The Reset Filter reminder will light every 6 months.
How do I get the turntable turned back on when using sensor reheat.
I appreciate your post, friend!
I see you are having trouble with the turntable motor on your Frigidaire microwave. The best way to reset your microwave is to disconnect power from it for roughly ten minutes. You can do that by flipping the household circuit breaker off. I hope that helps. -Matt
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
1helpful
Display reads clean filter even when the filter is out is there a nother filter inside
You need to reset the filter timer. Press the "options" button, then "3" for filter timer, then "start". The filter timer should now be reset and you shouldn't see it say clean filter anymore. Hope this helps.
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
1helpful
Microwave stopped working last night
If the microwave worked for a little while after you plugged it in again then it is just overheating.It is usually just dust/dirt collecting on the vents.the fan,and the magnetron(the thing the fan blows on).If cleaning all these doesn't solve the problem you may have a bad high temp overload sensor,and need to replace it.(this sensor is usually mounted directly on the top of the magnetron.The magnetron is the part that actually puts out the microwave signal.I've never seen a reset button.The high temp sensors reset themselves automatically.
Microwave Ovens Logo
Top Microwave Ovens Experts
Gerry Harvey
Gerry Harvey
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
