Question about FUJIFILM Cameras
Fujifilm finepix S1000
And if you do remove it, it is unlikely that you will have the equipment or the knowledge to fix the issue. Take it to a service centre.
Posted on Sep 15, 2017
SOURCE: I have FOCUS ERROR ON MY FUJIFILM FINEPIX s6500fd CAMERA
This is just a suggestion, as I am not an expert.A couple of years ago I had a problem with my older, Fuji Finepix camera related to the computer downloads/programming and I found Fujifinepix web site. I sent them an email and they responded and did not charge anything. Could try that..
Posted on Oct 29, 2008
SOURCE: HOW CAN I FIX MY LENS ON MY FUJIFILM FINEPIX J15?
The only thing i can think you could do is bring it to a repair shop they will repair it for free if there is warranty on it.. hope this helps
Posted on May 26, 2009
SOURCE: fujifilm finepix f40fd
An update to the initial posting. As a warranty service provider, I can state that physical damage as a result of mis-use is NOT covered under warranty. Lens problems caused by dropping the camera are considered mis-use and are not covered. There is a good posibility that the lens assembly is just out of timing and can be rebuilt, but the cost to do this will not be paid by the manufacturer.
I don't want you to believe that this repair will be for free as it will not.
Regards,
Dan
Posted on Nov 13, 2009
SOURCE: My FinePix S1800 Fujifilm Digital SLR camera says Frame No. Full''
Go to set up then Frame and change to RENEW. It is probably on continuous. My camera did the same thing and this solved it.
Apparently even thought the card is empty if it is on continuous it will start the picture numbering where you left off last time.
Posted on Oct 23, 2010
SOURCE: I have Fujifilm Finepix S1000. The battery door does not close
I know this is an old question, but when I had this problem I came across several forums that had the "tape it" or "drill a hole and screw it shut" solutions. Some even gave step by step instructions on taking the camera apart and replacing the battery compartment with one from a camera bought for parts. I even contacted Fujifilm for an estimate. All were either expensive, ineffective or damaging. The solution I came up with was to go to the Camera Exchange and buy a Quick Release plate used for tripods. One that was long enough to cover the battery door. It screws into the tripod mount on the back and holds the door closed. No damage, no hole drilling and it works. Also only cost me $8. Win!
Posted on Sep 25, 2012
Jan 01, 2016 | FUJIFILM Cameras
Jan 06, 2011 | Fuji FinePix S1000FD Digital Camera
Dec 09, 2010 | Fuji Cameras
Apr 03, 2010 | Fuji FinePix S1000FD Digital Camera
Mar 22, 2010 | Fuji FinePix S3100 Digital Camera
Nov 16, 2009 | Fuji Rod Repair Kit
Sep 12, 2009 | Fuji FinePix S1000FD Digital Camera
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Nov 25, 2008 | Fuji FinePix S1000FD Digital Camera
Aug 13, 2008 | Cameras
51 people viewed this question
