Question about Samsung Cameras
Samsung digimax A40 camera pictures to white - Samsung Cameras
Posted by john on
Tony Parsons
  • Samsung Master
  • 6,280 Answers
Please give further more detailed description of the error
Posted on Sep 15, 2017
5 Related Answers
Parshiv Luthra
  • 395 Answers
SOURCE: my samsung digimax s500 camera still says card locked every time i go to take a pic.Someone kindly sugested holding the rest button, but i
THe SD card inside has a lever to its left Side .... Move it upwards ..... That is the lock on the Memory Card ...
Posted on Oct 16, 2008
Anonymous
  • 11 Answers
SOURCE: Near light, Camera takes white pictures
Try putting it on the daytime setting.
Posted on Jul 21, 2009
Anonymous
  • 125 Answers
SOURCE: Samsung Digimax D53
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Posted on Jul 22, 2009
Anonymous
SOURCE: Overexposure on Samsung Digimax L60
Had same problem after 2 years. Took it in to a repair shop & they installed a new camera flex. Its working OK now.
Posted on Sep 09, 2009
Obertelli
Obertelli
  • 3006 Answers
SOURCE: i have a samsung digimax A7 camera the picture on
It's almost certainly a failed ccd sensor chip and if so it cannot be fixed unless the camera is still under warranty.
To confirm, check whether camera menus and photos taken before the fault occurred still display correctly; if they do then it rules out any fault with the LCD panel.
You can't repair this on a DIY basis and a professional repair is completely unrealistic as the camera is an ultra budget model which only cost around £60 brand new. Spare parts simply aren't available, and if they were then supplying and fitting would cost more than a new replacement. Even if under warranty still, Samsung would simply chuck your camera straight into the bin and send you another.
In this instance, even if the LCD panel is at fault then it's still not worth repairing for the same reasons.
Sorry, but in this instance your only option is to buy a replacement camera.
I hope that my reply has still been useful, if so please take a moment to rate my answer.
Posted on Feb 22, 2010
I get a message saying USB error on samsung A40 digimax camera when i want to connect to my computer to upload photos
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 07, 2013 | Samsung Digimax A40 Digital Camera
Where can I purchase a USB cable for the Samsung Digimax A40 Digital Camera?
Walmart, Kmart, Radio Shack, Best Buy, etc. Take your camera with you to be sure to get the right size for your camera.
Sep 28, 2009 | Samsung Digimax A40 Digital Camera
CARD LOCKED!
Try taking it out and looking for a white switch. Try flicking it.
Jun 02, 2008 | Samsung Digimax A40 Digital Camera
Pictures are red during the day.
U might need to change the mode in which u are taking the pics. Try setting it to Auto mode.
Mar 18, 2008 | Samsung Digimax D53 Digital Camera
Samsung digimax a40 camera driver
I have the same problem, I'm going crazy to solve it but I can't. I will appreciate if you already have a solution to contact me!! my e-mail address is [email protected]
Dec 12, 2007 | Cameras
Cameras Logo
43 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
