Question about Paradigm Audio Players & Recorders
Cancellation of the paradigm book - Paradigm Audio Players & Recorders
Posted by gary rutherford on
How do I cancel an order for a kindle book
How do I cancel an order for a kindle book - Amazon Kindle
1helpful
How do I stop my Paradigm sub from humming and "burping?"
The amplifier that powers the sub is the source of your problems. Sounds like some power supply filter capacitors are failing.
How to cancel a booking on 13cabs
Hi Aria,
If you are booking through the app, you can select 'Track Booking' & then find your current booking. Select the booking, hit options & then select 'Cancel.'
If you are booking via our website, click on the link that states 'View last booking' in the right hand corner. Then select 'Cancel.'
If you have booked via the phone, please call 13 2227 and advise one of our operators that you'd like to cancel your booking & provide the address.
Thank you,
Kirsty @13CABS
I have a 110v power input Paradigm PDR10 and would like to convert it to 220/240. I'm sure it's a case of change the series connection to parallel on the transfomrer but I'm not sure the exact functions...
I have the same problem. An external transformer would step down the voltage, but it wouldn't help with the frequency, which would still be 50Hz. Paradigm says there's a risk of burnout if an unmodified PDR-10 is run at 50Hz rather than 60Hz
Paradigm 5.1 to 7.1 system
The Dolby curcuit in the Paradigm must be Dolby 7.1 or it will simply not be able to send the extra channel signals to the speakers. In otherwords you will not get the full 7.1 sound from two speakers added to a 5.1 amp.
Paradigm Monitor 9 v4 tweeter not working.
speaker is must likely blown. check to see if another tweeter works at that connection.
1helpful
Can't find owners manual for paradigm cc-300 center channel
http://www.retrevo.com/s/Paradigm-CC-Speakers-review-manual/id/13247ci865/t/1-2/
Lightning struck and my paradigm ps1000 doesn't work anymore.
Paradigm service is excellent and they can supply parts. The amplifier has a one year warr. Check with a dealer or www.paradigm.com Your insurance may cover it.
Top Paradigm Audio Players & Recorders Experts
Ekse
 Grubhead
Grubhead
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
