Question about Pioneer Car Audio & Video
Hooking up a pioneer avh- x4800bs into a 2001 Pontiac trans am with the moon soon stereo system in it, which colors go to new pioneer of the pins 7-15,can you send me anything that will help
Posted by William Koutny on
ajschmitz6
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
I was at a Walmart or an auto parts store and saw some adapters that would adapt Vehicles factory wiring over to Modern car stereos - if you find the section in automotive with the adapters, you might be able to call the company and see if they have the adapter you need for your system.
Posted on Sep 15, 2017
  • ajschmitz6 Sep 15, 2017
5 Related Answers
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: Pioneer avh p4000dvd w/GMOS-04 wiring harness
I think you need a different harness, this one isn't handling the power I believe. What are the wire gauges
Posted on Jun 05, 2008
Anonymous
SOURCE: Pioneer AVH-P6000DVD
You cut the green brake wire leading to the brake and get a single pole switch from radio shack wire the green to the power part of the switch and get another piece of wire and ground it some where. when you want to play when driving click the switch and it will play while driving.
Posted on Sep 18, 2008
Anonymous
SOURCE: eject lock pioneer avh-p5000
Turn it off so you see the "demo" screen or the blank "off" screen, then hold eject + volume (mute) button down for few seconds to turn the eject lock off.
Posted on Oct 01, 2008
Anonymous
  • 64 Answers
SOURCE: pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Posted on Nov 25, 2008
Anonymous
  • 86 Answers
SOURCE: please help me enable the aux mode on the above
Have you tried going into the menu and searching for this function?Also some car stereo's have a sub menu when the radio is turned off or in stanby mode it usually can be reached by pushing your menu button and holding for a few seconds also again the power has to be in standby mode. if this works look through menu for your problem.
Posted on Nov 04, 2009
Testimonial: "Thank you, i will try ."
How to bypass pioneer avh-p5700dvd
The recent pioneer DVD devices structures setup is achievable by inspecting the vehicles default wiring kits to determine the most compatible medium. The prior wires in the vehicle stereo appear mutated with attempt to extract and replace with new DVD stereo. Inspect the mutilated wires to determine the kit harness that allows connecting the new device on one end while binding to the electrical cables extended surfaces. The new stereo player makes possible connection of a multipurpose harness that solves the problems that may be thought to require bypass. Once the appropriate connection kit harnesses are acquire, the wiring should provide connectivity to speakers, tweeters, woofers and several devices as amplifiers also necessary predicted during installation else missing audio may be detected after. Refer to auto installations experts to acquire the complementary parts to attain the installations.
Feb 05, 2011 | Pioneer AVH-P5700DVD Car DVD Player
Hooking up pioneer avh-p3100dvd trying to bypass the saftey brake wire to play dvd while driving how?
You should not do it it’s again the law, soon or late you will caught got
Jan 03, 2010 | Car Audio & Video
Install a pioneer AVH-P6800DVD
Here is a link to the manuals for this device:
http://www.pioneer.co.uk/uk/support/manuals/AVH-P6800DVD/index.html
1st manual is the installation manual, it is mislabled.
Cheers!
Nov 07, 2009 | Pioneer AVH-P6800DVD Car DVD Player
Have a pioneer avh-p6500dvd want to upgrade a new brain can I
Hi. I believe you you can as long as the connector for the data cable is the same on the brain that you want to upgrade to. Good luck.
Jan 21, 2009 | Pioneer AVH-P6500DVD Car DVD Player
Avh-p5700 pioneer
My first suggestion is to not purchase "used" electronics from eBay. I bought the same kind of unit from eBay... and mine is broken too. I got a cell phone, car stereo, and a remote.. they were all not working properly when I received them.
Did you try the restart button. It is a small, pin size button on the right-side of the unit near the 4-way select buttons. My player wouldn't eject a cd either, and when I pushed the restart button with a pin, the cd ejected and the unit was ok for playing cds... that's about it
May 04, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Car Audio & Video Logo
35 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
