Question about Acer Computers & Internet
I bought 4 Acer 15.6 laptops for online schooling.One of these laptops has a problem with battery. What do I do to return this one to you?
The laptop only works if plugged in for power. It says it has 80% charge and doesn't go any further, but when you unplug from electrical outlet it goes dark.
  • Anonymous Oct 13, 2021
    WE SELL NOT ONE COMPUTER HERE, ARE YOU THAT LOST?
    I BOUGHT FROM WHERE? NOT TOLD
    EBAY THEN SEND IT BACK
    FROM AMAZON TAKE IT BACK
    FROM BEST BUY TAKE IT BACK
    SEE A TREND HERE?
    THE BATTERY IS NO GOOD..
ray gallant
    Top Expert:
  • Acer Master
  • 73,593 Answers
AS THIS IS NOT A RETAIL OUTLET SENDING TO US WOULD ONLY GET IT BINNED AS WE DO NOT SELL PRODUCTS
Posted on Oct 12, 2021
  • Larry Ng
    Larry Ng Oct 13, 2021
    BINNED MEANS TRASH CAN, (ash canned,)
    IN UK.
    slang (or say rubbish can)
    the correct answer is
    take back to them and we are NOT THEM.
    OP open your desk take out the sales receipt for this PC, the sellers name and location and return it or get a replacement that is good.
    if bought off bad ol' ebay , if it said, sold "for parts , as Is. or no returns " you will fail."
5 Related Answers
Anonymous
  • 624 Answers
SOURCE: Laptop shuts off when unplugged, battery is fully charged
Chosenone, Even though the battery meter shows it fully charged I doubt it?s correct. Over time rechargeable batteries loose their ability to store power. How long depends on the battery manufacturer and how well you treat it but you can consider yourself fortunate if your battery lasts three or four years. Beware of people who suggest you take apart your batter to bypass the safeties or replace old battery cells. Defective or improperly handled batteries can overheat and cause fires when you least expect them. Let us know if you have any more questions and please don?t forget to rate this post.
Posted on Feb 24, 2007
listeur
Grant Cameron
  • 88 Answers
SOURCE: Dell c640 battery problem
This sounds like it is not getting enough amperage from the power brick- check which model power brick you have. I'm not 100% sure but the pa-6 family may not provide enough power to charge and run the laptop at the same time. the PA-9 should- if it's rated at 4.51 @20v - that works out to about 90watt. If you DO have a 90 watt power adapter and it's still giving the orange then red flashes- and will not charge when the laptop is off- you probably have either a bad battery, or the motherboard is faulty and has a bad charge circuit, or a loose power jack. What does pressing the little button next to the charge indicator on the battery do? Flashing every other led- 1,3,5 is BAD, so is 1 and 5. You also might have a 3rd party refurb- that had the guts torn out and is not properly "seen" by the laptop.
Posted on Dec 18, 2007
Anonymous
  • 432 Answers
SOURCE: laptop will not run while plug into the electrical system
Worst case is you need a another motherboard because the power supply unit and charging unit are on the motherboard. Then again it could be the DC power jack on the motherboard is loose and needs replacing. The website below is a link to a ebay site that sells these power jacks.
http://cgi.ebay.com/IBM-Thinkpad-T30-T30p-DC-power-jack_W0QQitemZ200216009749QQihZ010QQcategoryZ158847QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Also is an ebay site for T30 motherboards.
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=t30+motherboard
If your good with tools you can replace these parts yourself. Below is the IBM website where you can download the service manual in pdf.format and fix it yourself without taking it to a computer repair shop.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-42308
If this helps, Please leave a positive rating.
Thanks,
Ray
Posted on May 14, 2008
PCwolf
  • 7 Answers
SOURCE: XPS M1330 issue -- laptop won't charge battery
As he said it could be the battery so do test that but if it isnt its most likely a problem with the power socket itself as he said, and i do know that some computer repair companies can fix this sort of thing if you want to go to them for help
Posted on Aug 21, 2009
Testimonial: "Thanks for the input..."
Anonymous
SOURCE: laptop screen went black
When I opened my laptop this morning my computer won't come on. The screen is totally black. I took out the battery and put it back in ---- still nothing. I plugged it in with the power cord --- nothing! What is wrong with my HP Compaq Presario CQ60?
Posted on Jan 05, 2010
1helpful
Acer aspire 4339 wont turn on with new battery
That means the laptop is not detecting the battery as authentic or full enough to boot the laptop. Most batteries are now smart batteries, so the battery you bought may be an aftermarket battery not supported by the laptop. Return it and cite the issue.
2answers
Fit my Acer Aspire 3000 ?
akku Acer Aspire 3000 100 percent compatible with you Compaq Presario CQ61. I bought two Acer Aspire 3000 batteries from http://www.pcakkus.com/acer-aspire-3000.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
My Acer Aspire Nav50 was just fine a few weeks ago but now cannot get above a 5% charge. It is only about 15 months old and I have reason to believe the battery is just fine but possibly has a bios...
There is a known issue with a BIOS bug in some of the Acer models that it prevents charging. Try upgrading the BIOS from Acer online to the latest version following the online instructions.
I have an Alba tv and a acer laptop. I bought a 15 pin VGA cable and connected it to my tv but it is just saying no signal on the tv, can you help?
Since you have a Cable , I supposed you did pluged it in... one side in the Input of your TV and the other side in the VGA connector on the side of your ACER,
Once this is done you have to press and Hold the FN Key of your Acer and press the F5 keyA menu will display 4 icons an icon of your ACER, your ACER and a monitor, a monitor only and an icon of a projector.
press F5 Twice and the signal will show on Both your Acer and to the TV
Tree time will send the signal to the TV only Five times and you will return to the Icon list on your ACER
1helpful
2answers
Hello, As i was working on, suddenly my laptop was shut down without any indications. and i tried to start it but it did not. after plugging in the battery charger it started. After that if i remove the...
Looks like you have a faulty battery, since you bought your laptop 4 months ago, I think it is still covered by their warranty. Please try to contact the manufacturer about the possible battery replacement. :)
Some of the things to do/check if the manufacturer requires you to return your laptop to them: 1. Backup all your important files to a different media/storage, like an external hard drive or burn them to blank DVD's
2. You can also tell them that it MIGHT be your charger that's faulty. Either way, they SHOULD check the battery and charger.
2answers
What is the bios password for an acer aspire 5100
It sounds to me like it was set by someone other than yourself. There is no legal way to reset the BIOS password. You can contact the person who set it, call Acer for service, or if you bought this from someone, return it.
If you set it, try to remember what it was.
Acer aspire 10.1, the battery won't charge to 100%,
check the battery model number matching with laptop
lot of duplicate battery in market
return back the battery to supplier
Computers & Internet Logo
Ekse
Steve Sweetleaf
Steve Sweetleaf
Michael Thomas
Michael Thomas
