Vacuums Logo
Question about Bissell Vacuums
My bissell crosswave turns itself off - Bissell Vacuums
Posted by izapeacock on
Rollers aren't turning on my Bissell Crosswave, more is it sucking up the water.
check back of nozzle housing for reset on kenmore upright
Bissell Crosswave model 1785F no power
Here's a video tutorial on how to fix it:
https://www.bissell.com/bissell-crosswave-multi-surface-wet-dry-vac-1785/no-power-how-to-videos-crosswave
hope i was able to help
Bissell crosswave brush won't turn. It's not the brush, but the part that actually turns the brush. I've cleaned it out carefully, and I've used a lubricant multiple times, but nothing helps.
I'm not familiar with this particular model but there should be a rubber drive belt at one end of the brush that get stretched from the brush end to a small shaft that sticks out the over the same end above the brush. Reassemble the shroud and try it again.
2answers
Does the bissell crosswave have a belt. The brush roll won't turn.
If the motor sounds like it is turning, but the brush doesn't spin, then the belt is likely damaged. Check on line to find the part and replacement instructions.
Top Bissell Vacuums Experts
Marvin
Marvin
David Shaub
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
