Most TVs don't have a built-in satellite receiver. You'll need to buy and install a suitable satellite receiver box for the signals that your dish is capable of receiving. The dish connects to the satellite receiver. Then the sat receiver connects to the TV via either AV cables or HDMI. Hope this helps.
The dish network reciever should have audio and video out on the back, If its a HD device it should also have COAX out (hd audio) get the cables for audio and feed the into a input on the back of your home theater system, there should be several inputs, usually labled like video 1 video 2, tape deck etc etc. the audio in are red and white or red and black usually, the coax connector is orange, and you only need one cable to hook that up. If you have HD audio on the dish network that will sound best in your home theatere system
If the cable comes from the dish,then unless you have a freesat tv that will not connect into your tv.The cable from a dish normaly connects into a sky box or cable box.You need a cable from an aerial to connect into the tv.
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
ya dish network reg box isnt hd ok u need call dish get hdtv box then u can use hdmi cable to get hi end picture ok for now use cox cable like u do to u can upgrade dish hd sumday k
