SOURCE: 88 s10 pickup truck will not shift from 3rd gear to overdrive
need more info i had a 1984 chevy half ton and first, second, and third worked fine but lock up didnt work. the problem was there was no vacum at a switch under the hood on the fire wall also your shift linkage could be out of adjustment. try driving down the road and raise up a little on the shifter.
SOURCE: hard shift from 1st to 2nd gear automatic
what year is vehicle please ?? as people often put it in wrong catagory ,if its mazada 2007 then its dealer only as a computer controls it all and the software is factory encrypted to stop general garages from repairing it .But check for a vacumn pipe loose under bonnet ,thin rubber pìpe from inlet manifold to gearbor or a diaphram switch,
SOURCE: automatic transmission not shifting into 3rd or 4th
my 1999 f250 super duty will not shift into overdrive
SOURCE: 2005 GMC 4wd pickup. I just lost 3rd gear and
you smoked your trans 3-4 clutches gone need overhaul
SOURCE: Renault Megane Scenic 1.6 petrol jerking in 1st & 2nd.
check hoses for splits...i had the same problem.
