Question about D-Link Computers & Internet
Can't find Dlink
D-Link can't find Wi. Fi network
Posted by Kenneth Trafford on
5 Related Answers
drlalitv
Lalit Varadpande
  • 488 Answers
SOURCE: secure my network (wi fi TP-LINK) model no: TL-WA601G
two options:one is to run the cd that came with the router and follow the wizard and configure the network..other is to log into the router by typing 192.168.1.1. or 192.168.1.1. in the browser or if any IP address mentioned on the body of the router please use that..enter the login and password..usally admin and admin by default..go to the wireless security and set it up..u can also change the network name etc..there will be a provision to backup the settings too..please don't settings that u don't know about as they can misconfigure your network..hope it helps!
Posted on Nov 07, 2008
Anonymous
  • 11 Answers
SOURCE: one click link for wifi driver for compaq V3000
the Compaq website is showing two possible wifi drivers..
http://h10025.www1.hp.com/ewfrf/wc/softwareList?lc=en&dlc=en&cc=us&os=228&product=1817059
If you go to the link above and go down to network and then choose either Intel Pro/Wireless drivers or Broadcom Wireless LAN driver. (I would probably try the Intel driver first).
Download them to your desktop and then double-click on them and follow the install instructions. If the first one doesn't work go back and try the other.
Posted on Feb 11, 2009
Anonymous
SOURCE: I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
Posted on Feb 24, 2009
meteshadow
  • 489 Answers
SOURCE: NETWORK IS NOT CONNECING IN wi-fi in our wireless network with WPA2 system. but its detecting the network. should i install any new software to support WPA2.
try to setup again  wireless card's driver  if it doesnt work your wireless car is break down.
have a nice day and sorry for english.
Posted on May 27, 2009
How to change password to my router
How do I change the Wi-Fi Password on my router? ' D-Link ...
www.dlink.com/.../routers/...routers/.../how-do-i-change-the-wifi...
D?LinkMethod 1. Step 1: Open an Internet browser (such as Internet Explorer) and enter http://dlinkrouter.local or http://192.168.0.1 into the address bar. Step 2: Enter ...
Changing your wireless network password - Linksys
www.linksys.com/cz/support-article?articleNum=135554
LinksysHow do I change the password of my router's wireless network? ... NOTE: If you have a Linksys Smart Wi-Fi Router (EA9200, EA6900, EA6700, EA6500, EA6400 ...
Dec 29, 2015 | Computers & Internet
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
Hard drive crashed lost my dlink disc how would i put my dlink router on my new computer
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 13, 2010 | D-Link High-Speed 802.11g Wireless PCI...
How to set up dlink wireless router withot the cd
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Nov 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
What is the default password
First connect your router to computer with ethernet cable.
http://192.168.1.1
or
http://192.168.0.1
then go to wi fi security set your WEP code it is your security key to connect wi fi network.
Change it and then save settings and restart router.
Let me know if you need more assistance.
Thanks
Oct 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
We have aa dlink DIR615 router. Can you tell me
This button is used to quickly set up wireless networks with the WiFi Protected Setup.
Wi-Fi Protected Setup is used to easily add devices to a network using a PIN or button press. Devices must support Wi-Fi Protected Setup in order to be configured by this method
more information is available in your manual and this forum
If this helped you then please help me and vote kindly, thank you.
Oct 11, 2009 | D-Link (DI-711) Router
How do i install my WIRELESS G ROUTER without the cd
you don't need to install a router on a PC. The wireless card or ethernet cable should talk to the router.
Sep 21, 2009 | D-Link DIR-300 Wireless Router
I have forgotten my dlink user password for my home network Help?
http://192.168.1.1
or
http://192.168.0.1
then go to wi fi security check your WEP code it is your password to connect wi fi network.
Let me know if you need more assistanse.
Thanks
Sep 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
Connecting my i-touch to a Wi-Fi connection
Yup....you'll need a small router. I use a DLink WirelessB unit. Ask your local computer store for a small router, just an inexpensive unit. DLink or Linksys are the best. If you're uncomfortable trying to set up a home network, get the Geek Squad to do it for you. If you have any more questions, get back to me and I'll try to help more.
Jan 03, 2009 | Apple iPod touch
Problem with D-link airplus wireless network card for my desktop
You need more memory and a faster machine. Better yet get a machine will all that wi-fi stuff built in. The add on solution needs a lot of tinkering.
Dec 07, 2008 | Cornerstone DLink AirPlus DWL-520+ 802.11b...
Computers & Internet Logo
63 people viewed this question
Top D-Link Computers & Internet Experts
Mike
k24674
Muntejaya Ginting
Muntejaya Ginting
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
