Computers & Internet Logo
Question about Medion Computers & Internet
Medion won't connect to mobile hotspot
Posted by Lesley Robinson on
Polaroid tv not get connected with wifi
Restart your mobile hotspot and your cellular data connection. Many times, a quick hotspot restart will fix problems with mobile hotspot internet connection. Boost the quality of your mobile signal.
Install hot spot in galaxy prime core
From the Home screen, touch Apps .Touch Settings .Touch More networks .Touch Mobile Hotspot.Touch the slider to turn Mobile Hotspot on . If you are connected to a wireless access point, you will be disconnected before you can use the hotspot. Touch OK to continue. The Wi-Fi hotspot icon is displayed at the top of your screen when the hotspot is on.
My PlayStation 3 was working fine with my mobile hotspot then it gave me the error 80028E06, how can I fix this problem.
You may have run out of data or simply the mobile hotspot is now slower due to ISP throttling and therefore the connection is timing out on the PS3.
80028E06 Connection with server timed out
How do I get my tablet connected to mobile data?
Most cell phones have a built-in wireless hotspot option. On Android, go to Settings, under Wireless and Networks there should an option for Tethering & portable hotspot, setup the hotspot settings first, then turn on the hotspot, and make sure your 3G/4G/etc data is enabled, then have your tablet connect via wireless to your phone's hotspot and you're good to go. Good luck.
How do you Connect asus laptop to portable hotspot
On the right hand side of the taskbar you should see what appears to be an icon like signal bars on a mobile phone. Clicking on this will open a box with available hotspots or access points. Click the one you wish to join and then click connect. After an interrogation of the hotspot it will either connect automatically if there is no security required or a dialogue box will appear asking for the password or network key. This is case sensitive so enter it exactly as it appears on the hotspots sticker or as supplied by the hotspot owner. If you enter the correct key it will then connect and you will have access to all the features provided by that hotspot. Most hotspots and personal access point devices also have a button that you can press to initiate a connection without knowing the password.
Why am I having a problem using my virgin mobie hotspot with my samsung galaxy tab 8.0
What kind of problem are you having? Is it the hotspot itself or the connection to the tablet? Does the tablets internet setting recognise the hotspot? If so, then the hotspot is not the problem and you should investigate the settings to connect. Usually, if a hotspot is transmitting a signal, the on/off light will be flashing. If yours is, then again, check the tablet internet settings.
Medion pc mt6 wifi switch? desktop no fn key
http://www.medion.com/gb/service/download/driver.php, go to this website, enter your msn number and download the software that will activate the hotspot keys to enable your wifi.
Viewing youtube videos is blurry using a sprint aircard
When viewing YouTube videos through a mobile hotspot (especially Sprint!) it can be blurry because the connection can be very slow. If you want to increase the quality select the gear in the lower right-hand corner of the YouTube player and select 480p or above. This should improve the quality. Hope I could be helpful.
Can not connect to moble hotspot
You may need software installed on the PC to connect, do you have a Wireless Card or a USB wireless adapter in the PC? Your Mobile Hotspot is a phone? Check the Phone Manufacturer's website/support for "How-to".
Hp dv7 won't connect to mobile hotspot
RUNNIG WIN XP? READ THIS http://www.fixya.com/support/r7858944-working_widows_wireless_networks
Top Medion Computers & Internet Experts
 Mike M
Mike M
Marvin
Marvin
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
