SOURCE: brother MFC-5860CN print unable 51 error message
Normal
0
Could have a corrupt driver.
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: How do I clear
51 error says that the purge assembly is stuck and not cycling properly. If you can power up and get the printhead to the center and unplug again, look with a flashlight in the far right corner where the printhead parks for any paper scraps or things that don't belong and remove them it might work again. Otherwise a shop repair to possibly replace the cleaning assembly.
SOURCE: brother MFC-465CN printer Error code 51 unable to print
Usually this is caused by a foreign object or debris under the printhead path, or under where the printhead "parks."
Unplug the machine. Open the cover. Check the printhead path for little bits of paper, push pins, paperclips, staples etc. Note the location of the printhead.
If the printhead is at the far left, gently slide it towards the center (do not force it). Look carefully under where the printhead was stopped for debris. Use a flashlight if necessary.
Close the cover. Plug in the unit. Try again.
SOURCE: I have a brother MFC665CW getting an error code
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
SOURCE: Will not print error
All the best good luck
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
To exit type 99
Also can try.
Solution:
· Machine off
· Press 80
