My jam transit wireless headphones won't charge at all, I've kept it plugged in for 3 days now and it won't charge. Help me please.
Posted by Desi McFaggan on
Genevieve Gelatto
    New Friend:
Same issue with my Jam Ultra Wireless Earbuds. I've had them less than a year. The charger/case is fully charged, and ONE of the buds still charges & connects fine. The bad earbud ALWAYS gave me trouble charging & connecting, ever since I first bought them, but would eventually work after much hassle. No more. It flashes blue & red, as if it needs to be charged, but won't. And yes, I'm making sure it's fully connecting when seated in the charger/case. To the ignorant jerk who said we "must be over 70", "replace the battery", the battery CANNOT be replaced. Dolt. Looks like the only solution is to buy another set, or better yet, get the Apple earbuds I should've bought in the first place.
Posted on May 19, 2019
alanrsm
    Habit-Forming:
  • 95 Answers
I am guessing you are over 70...replace the battery in the unit.
Posted on Jan 09, 2019
4 Related Answers
e-Guru
e-Guru
  • 3917 Answers
SOURCE: canon pixma ip1900 paper jam
Hi
Here's a few things you can try :-
1. Blow it out with canned air. make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. Take the network out of play when doing the initial troubleshooting
5. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.
Also if your Canon printer has fax capabilities, and you are getting a false paper jam error, the problem is easy to fix.
Open the scanner lid.
You will see a white strip on the left, under the lid.
There are also two small, white tabs near this strip.
Gently pull on each tab. You should feel a small "click" on the tab that is jammed.
This fixes the problem.
I suspect that when previously scanning something like a book page, one of these tabs got pushed the wrong way.
Hope it will help.Also you can get back to me if you need further assistance.
Thankyou.
Posted on Dec 05, 2011
terry stevens
  • 991 Answers
SOURCE: My ford transit 2.4 bus kepts cutting out and the battery light kepts coming on. Change the battery and the bus runs for a couple off days The the same problem kepts coming back Any one help pls
Sounds as though you Alternator or Charging system is not keeping up to the electrical demands. I would be checking the electrical connections and wires from the alternator for lose or burnt fittings. If you have a multimeter check the voltage output of the alternator.
Posted on Feb 28, 2015
ka4iup
ka4iup
  • 4062 Answers
SOURCE: My Jam Transit wireless headphones won't turn on. How do I get them to turn on?
https://www.youtube.com/watch?v=BcQF14i0n6w 2:30 minutes.
Make sure they are charged, then pair with device.
Posted on Mar 17, 2015
emissionwiz
Marvin
  • 85239 Answers
SOURCE: My Qy7 headphones wont charge or turn on . I've plugged them in for days but still show no sign of charging or turning on. Someone please help!!!!
Test the charger voltage is it working? You will need a DC voltmeter.
Posted on Nov 04, 2016
Jam hx-hp420 wireless headphones only plays when its connected for recharge battery, when unpugged the charging cable headphones turn off right away
Looking at reviews from their websites, plenty of people have problems with them. Sounds like it's either the battery, or the charge circuit in them. You might want to try one of the battery packs that are used to recharge cell phones if you want to use them. JAM Transit Bluetooth Headphones
[email protected] is their customer service email
for power banks Amazon com Portable Power Banks Cell Phones Accessories
Jan 21, 2017 | The Audio Players & Recorders
Can the battery in my headphones be replaced?
All batteries can be replaced if you can get to them, which is often the problem. If you can get the serial number off the battery, these people are good. Battery Buyer Batterybuyer com
Nov 10, 2015 | Jam Transit Wireless Headphones White...
Charging problem?
The battery in the headphones is most likely not taking a charge anymore and will need to be replaced with an equal value rechargeable battery
Jan 04, 2014 | TekNmotion Airhead 1000 Wireless...
On my macbook air, the volume isn't working
Check the headphone jack on the side of your laptop. If you can see a red light inside the jack, then the sensor that determines when headphones are plugged in is dirty or jammed. Compressed air and/or removing and inserting a headphone cable repeatedly can sometimes fix it for a while.
Aug 07, 2017 | Apple MacBook Air
Onn Wireless Mouse has stopped working. What do I do?
Mine would work fine until I turned on my wireless headphones...then the mouse would move a little stop.....move a little....then stop.
I made sure my headphones were on.
I turned off the mouse, moved the mouse reciver to a USB port on the front of my computer (the mouse reciver and the headphone receivers were next to each other on the back of the computer). I turned the mouse back on.
The computer imediately gave me the "installing USB driver" notification.
When it was complete....both played nicely together...no more problems.
Jun 28, 2012 | Computers & Internet
My Bose QC15 won't turn on, I've already tried replacing the battery. What could be the problem?
Mine did this as well, totally frustrated I kept on rapidly switching them on and off, and eventually it just switched on!
Mar 25, 2012 | Bose QC15 Headphones
My literati ereader will not charge. i kept plugging it in to charge and it would never connect and now the battery has completely died and the reader won't turn on.
If you've got any wiggle in the connector on the device, it's broken lose. If not, you've got bigger issues. Either way, it's a trip to the shop, or replacement time.
Jul 06, 2011 | Audio Players & Recorders
Headphones change batteries
Any luck with that model number??
Apr 06, 2008 | Radio Communications
2,715 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
