Computers & Internet Logo
M
Mark Stuewr Posted on Sep 13, 2017
Setting up new Acer laptop, selected wrong time zone on first page, went to next page. How do I return to first page ?
5 Related Answers
Shamsh
  • 81 Answers
  • Posted on Jul 23, 2009
SOURCE: My 4 month old laptop continually changes the time
ask the vendor to change the CMOS battery of the computer
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: Hi For some reason, maybe I bumped something, if I
if the settings are not selected in the control panel., then re-install windows or contact with the representative of the company from where you bought it.
Anonymous
  • 2501 Answers
  • Posted on Jul 24, 2010
SOURCE: setting time zone
I assume that you do not have a manual for your watch, so you can get one by going to their web site http://www.lacrossetechnology.com/support/manuals.php and choose the manual for your watch.
Anonymous
  • 531 Answers
  • Posted on Aug 25, 2011
SOURCE: running W7 on an
Hi
You do not identify your laptop model.
Try toggling the central button which on some laptops locks un unlock the touchpad/mouse controls.
If this is not the problem, reinstall the touchpad drivers from the driver CD or downloaded from the Acer website to clear any possible corruption.
www.acer.com > support > driver downloads
If this does not solve the problem there may be a hardware fault with the touchpad.
An experienced technician would have to open the laptop and lift the chasis cover to isolate the touchpad and check for a loose cable, liquid spillage damage or component failure.
A replacement touchpad itself will not be expensive and the cost of repair should not be prohibitive.
If the fault is in the motherboard contorller/connector of the touchpad, then repair (replacing the motherboard) may be uneconomical.
a USB mouse will work just fine on a laptop.
I hope this helps.
Anonymous
  • 7 Answers
  • Posted on Mar 13, 2013
SOURCE: My new Acer V5 (running windows 8) has the time setting correctly set for Pacific zone time, but the screen shows a time that is 16 hours in the future. How do I get the time to be correct?
Check the BIOS settings. My guess is that the date is off in the BIOS.
How do I set time zone? S/N: 502 16764PH.
Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there's nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet clock radio as follows: ZONE 1 - Atlantic Time ZONE 2 - Eastern Time (Default Setting) ZONE 3 - Central Time ZONE 4 - Mountain Time ZONE 5 - Pacific Time ZONE 6 - Yukon Time ZONE 7 To c h a n g e t h e d e f a u l t t i m e z o n e d i s p l a y, depress the TIME ZONE button. The number "2" will appear on the display indicating that the default zone is ZONE 2, Eastern Time. Hold theTIMEZONE button and then press either the or buttons your own time zone appears on the display, then release the buttons. The clock display will change to the correct time in the time zone you selected . The clock will always return to the correct time in the zone you selected after every power interruption. http://www.emersonradio.com/resources/owner_manuals/manual_1396274206.pdf
tip
How to reset Acer Aspire 5315 notebook to factory setting
There are two ways to reset the Acer Aspire 5315 notebook to factory setting which also means to reset it to the original setting.
The first way to reset the Acer Aspire 5315 to factory setting:
  1. Log-in as Administrator (if you have more that one account on your notebook).
  2. Go to Start.
  3. Select All Programs.
  4. Then select Accessories.
  5. Press System Tools.
  6. After that, press on System Restore.
  7. A page will appear, press Restore My Computer.
  8. Next, press next to continue.
  9. A message will appear, press Ok.
  10. Press next to confirm the restore point.
  11. The system will be restored.
  12. Restart the notebook.
The second way to reset the Acer Aspire 5315 to factory setting.
  1. Turn on the Acer notebook.
  2. Wait for a few seconds until you see the 'startup' process appears on the screen.
  3. As soon as you the 'startup' on the screen, press Alt+F10 for about five times.
  4. This will set the notebook automatically to factory setting.
**Try these steps at your own risk. Make sure to save on a Pen drive or USB Flash Drive any important documents/files before resetting your notebook.
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
2helpful
2answers
How to reset myacer to manufact setting
  1. Consider what data you still need from your Acer Aspire One's hard drive. Save the files to an external USB device.
  2. Restart the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
  3. Press the "Alt" and "F10" keys at the same time to bring up the recovery menu. Press "Enter."
  4. Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
  5. Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
  6. Connect the external USB device to your Acer Aspire One and transfer the data you saved earlier back to the netbook.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
I used my acer aspire 5315 and restored to factory default using empowering technology and now everytime i start up it keep trying to reinstall the restore programe that came with the computer
There are two basic ways to restore Acer 5315 PC Notebook to the original setting. The first method you can try to pressing the key Alt + F10 for 5 times while startup process appears on the Acer screen. Usually this way will restore the original setting automatically.
And the next method you may need to use system restore at the first time you’ve got your Acer 5315 laptop. Here are steps to follow:
Log on as the Administrator => Start => All Programs => Accessories => System Tools => and click the System Restore. System restore will run and here you should see the Welcome System Restore page appear. Click Restore my computer button to an early time if it’s not already
selected. Click next to continue the steps.
There is on your Acer 5315 laptop screen a Restore Point page appear, you can select it and then click the most recent system checkpoint it, click a restore point list. After you click the Next button, System Restore message may appear that lists configuration changes that
System Restore will create. Click OK.
For the last step click next button on the Confirm Restore Point Selection page. Now the ‘System Restore’ will restore the previous Windows XP configuration on your Acer 5315 OS system. Just finish it by restarts your Acer laptop.
Now log on again to your Acer 5315 PC Notebook as Administrator and watch the System Restore Restoration Complete page
JAIN_IT {INDIA}
1helpful
4answers
The time on my gps 1440 is 1 hour fast?
To switch between Daylight Saving Time - on or off:
1) Turn on unit - Press the picture of the wrench and screwdriver at the bottom.
2) At the next page, select "System"
3) At the next page, select "Time Zone"
4) Select "Daylight Savings Time" at the bottom to toggle it on or off
5helpful
3answers
How 2 factory reset an acer aspire 5315 laptop
Now log on again to your Acer 5315 PC Notebook as Administrator and watch the System Restore Restoration Complete page appears. Click OK.
3helpful
2answers
How do i do recovery on my acer aspire 5315-2153
There is on your Acer 5315 laptop screen a Restore Point page appear, you can select it and then click the most recent system checkpoint it, click a restore point list. After you click the Next button,System Restore message may appear that lists configuration changes that
For the last step click next button on the Confirm Restore PointSelection page. Now the ‘System Restore’ will restore the previous Windows XP configuration on your Acer 5315 OS system. Just finish it by restarts your Acer laptop.
13helpful
Starck clock wrong time zone
-Make sure clock is in radio sync mode. This is in the manual so won't repeat here.
-Press & release SELECT. Clock time numbers should flash
-Press & hold SELECT. It should enter clock settings mode
-Bottom of screen next to moon phase you should see the current time zone. PST after reset
-UP & DOWN will move through time zones.
-Press & release SELECT when done.
-Each time SELECT is pressed will move to a new setting like 12/24 hour etc.
-Press SELECT until clock numbers stop blinking or leave it alone to return to normal mode
-This should also work on the other Oregon Scientific Starck models.
Resetore back to fac. settings
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
